Upgrade ASR1001-HX from IOS 16.9.5
rshum
Beginner
Beginner
I'm currently running X86_64_LINUX_IOSD-UNIVERSALK9-M and encountered a bug that reboots the router. TAC advised I upgrade the IOS. I'm looking at X86_64_LINUX_IOSD-UNIVERSALK9-M. Are there any considerations I should take into account?
Thank you for the information it's exactly what I was looking for.
7 Replies 7
balaji.bandi
VIP Community Legend VIP Community Legend
what is the target version, some time you may need to upgrade ROMMON.
can you post show version
BB
rshum
Beginner
Beginner
BB
Here is a
 sho ver
Cisco IOS XE Software, Version 16.09.05
Cisco IOS Software [Fuji], ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.9.5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Thu 30-Jan-20 18:53 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2020 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
nw-router uptime is 5 days, 4 hours, 55 minutes
Uptime for this control processor is 5 days, 4 hours, 56 minutes
System returned to ROM by Critical process cman_fp fault on fp_0_0 (rc=134) at 01:15:49 EDT Thu Jul 16 2020
System restarted at 06:32:58 EDT Wed Jun 8 2022
System image file is "bootflash:asr1000-universalk9.16.09.05.SPA.bin"
Last reload reason: Critical process cman_fp fault on fp_0_0 (rc=134)
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Type: Permanent
License Level: adventerprise
Next reload license Level: adventerprise
The current crypto throughput level is 0 kbps
Smart Licensing Status: Smart Licensing is DISABLED
cisco ASR1001-HX (1SR) processor (revision 1SR) with 3853044K/6147K bytes of memory.
Processor board ID
Crypto Hardware Module absent
8 Gigabit Ethernet interfaces
8 Ten Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
16777216K bytes of physical memory.
29401087K bytes of eUSB flash at bootflash:.
0K bytes of WebUI ODM Files at webui:.
Hello rshum,
You want to upgrade to which version?
Thanks.
Marin Grabovschi
Leo Laohoo
Hall of Fame Community Legend Hall of Fame Community Legend
This router crashed on 16 July 2020 due to
cman_fp fault on fp_0_0 (rc=134).  fp_0_0
is a "generic" reason.
Are there any crashinfo files available?
What is the output to the command
sh log on uptime?
IMPORTANT:  Everyone is asking what version you want to go to because it is not possible to upgrade the firmware unless the ROMMON is upgraded.
Cisco ISR & ASR 1k Routers: IOS-XE/Firmware Upgrade (Install Mode)
rshum
Beginner
Beginner
I'm looking at 17.3.5 MD
Hello rshum,
I would advise checking ROMmon Release Requirements Matrix and Hardware Programmable Requirements:
https://www.cisco.com/c/en/us/td/docs/routers/asr1000/rommon/asr1000-rommon-upg-guide.html#concept_zdm_2nx_5bb
But you shouldn't have any compatibility issues.
The only thing that comes at the top of my mind is the change in licensing used (in case you have licenses installed on your box).
Since IOS-XE 17.3.2, the licensing on IOS-XE products changed from Smart Licensing to Smart Licensing using policy.
Further on the topic, I will leave here some documentation for you to check.
Configure Smart Licensing Using Policy On IOS-XE Routers - https://www.cisco.com/c/en/us/support/docs/ios-nx-os-software/ios-xe-17/217046-configure-smart-licensing-using-policy-o.html#anc1
SLUP videos - https://community.cisco.com/t5/cisco-software-documents/new-deployment-method-for-smart-licensing/ta-p/4167670
Smart Licensing using Policy on Catalyst Switching Platforms - https://www.cisco.com/c/en/us/support/docs/switches/catalyst-9300-series-switches/216545-smart-licensing-using-policy-on-catalyst.html#anc0
SLUP FAQ - https://community.cisco.com/t5/networking-documents/smart-license-using-policy-faq/ta-p/4415506
Thank you.
Marin Grabovschi
Recognize Your Peers
