06-14-2015 05:58 AM - edited 03-05-2019 01:40 AM
Ok all. I have a issue. I have a flat network that will consist of 2 cable DSL connections. One using DHCP and the other using a static route. These will connect to a ASA 5506x (I have not configured one of these before). The ASA will connect to a 3650x switch. There are 3 total vlans not including the management
I have
VLANS 100 (business)
192.168.104.0/24
VLAN 101(Guest)
172.17.104.0/24
VLAN 200 (Voice)
172.16.104.0/24
Vlan 100 and 200 will go out through the ASA to the static routed DSL modem. While vlan 100 should go to the DHCP modem.
I configured the connection from the switch to the asa as a trunk port and have configured 3 subinterfaces on the ASA. As I am trying to put in route statements on the ASA to get it to send the traffic out I keep getting the error (Cannot add route, connected route exist)
I need some help please.
Thank you
06-14-2015 06:47 PM
Are you trying to configure policy based routing on the ASA? Have a look at the following doc:
John
06-14-2015 07:31 PM
One of the ways to have ASA send some traffic through one connection and other traffic through some other connection is through configuration of Policy Based Routing. The post from John makes the point that this feature was introduced in release 9.4. So our first question should be what version of code is running on your ASA?
The original post says that you tried to configure routes and received an error response. Without knowing the specifics of what you were trying to configure it is difficult to understand what is the problem and what to do to solve it. So can you post the specifics of what you were attempting to configure?
Rick
