Help with configuring GRE over IPsec
CavanP11
I'm trying to create a encrypted tunnel use GRE over IPSec, but I am unable to get it to work. I believe I'm messing up my ip routes and getting them confused. My tunnels work before I try to encrypt them, but when I attempt to do it, I can no longer ping them anymore. The IP routes on the routers below are fine, I haven't left tin my attempt at doing them.
In case it's needed, the whole network is 10.100.0.0/19
This is a screenshot of it currently.
Carlow Router:
Building configuration...
Current configuration : 2572 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Carlow_Router
ip cef
no ipv6 cef
license udi pid CISCO2911/K9 sn FTX1524693Y-
license boot module c2900 technology-package securityk9
crypto isakmp policy 102
 encr aes
 authentication pre-share
 group 5
crypto isakmp key cisco address 149.153.1.6
crypto ipsec transform-set CarlowBelfast_Set esp-aes esp-sha-hmac
crypto map CarlowBelfast_Map 102 ipsec-isakmp
 set peer 149.153.1.6
 set transform-set CarlowBelfast_Set
 match address 102
spanning-tree mode pvst
interface Loopback0
 ip address 1.1.1.1 255.255.255.255
interface Tunnel0
 ip address 172.16.250.1 255.255.255.252
 mtu 1476
 tunnel source Serial0/0/0
 tunnel destination 149.153.1.6
interface GigabitEthernet0/0
 no ip address
 ip nat inside
 duplex auto
 speed auto
interface GigabitEthernet0/0.10
 encapsulation dot1Q 10
 ip address 10.100.0.1 255.255.255.128
 ip nat inside
interface GigabitEthernet0/0.20
 encapsulation dot1Q 20
 ip address 10.100.0.129 255.255.255.224
 ip nat inside
interface GigabitEthernet0/0.30
 encapsulation dot1Q 30
 ip address 10.100.0.161 255.255.255.224
 ip nat inside
interface GigabitEthernet0/0.40
 encapsulation dot1Q 40
 ip address 10.100.0.193 255.255.255.224
 ip nat inside
interface GigabitEthernet0/0.50
 encapsulation dot1Q 50
 ip address 10.100.0.225 255.255.255.224
 ip nat inside
interface GigabitEthernet0/0.60
 encapsulation dot1Q 60
 ip address 10.100.1.1 255.255.255.240
 ip nat inside
interface GigabitEthernet0/0.70
 encapsulation dot1Q 70
 ip address 10.100.1.17 255.255.255.248
 ip nat inside
interface GigabitEthernet0/1
 no ip address
 duplex auto
 speed auto
 shutdown
interface GigabitEthernet0/2
 no ip address
 duplex auto
 speed auto
 shutdown
interface Serial0/0/0
 ip address 149.153.1.2 255.255.255.252
interface Serial0/0/1
 no ip address
 clock rate 2000000
 shutdown
interface Vlan1
 no ip address
 shutdown
router ospf 1
 router-id 1.1.1.1
 log-adjacency-changes
 network 10.100.0.0 0.0.255.255 area 1
 network 149.153.1.4 0.0.0.3 area 1
 network 149.153.1.0 0.0.0.3 area 1
router ospf 2
 network 172.16.250.0 0.0.0.3 area 2
ip classless
ip route 0.0.0.0 0.0.0.0 149.153.1.1
ip flow-export version 9
access-list 102 permit ip 10.100.0.0 0.0.255.255 10.100.0.0 0.0.255.255
line con 0
line aux 0
line vty 0 4
 login
end
Belfast Router:
Current configuration : 2479 bytes
version 15.1
hostname Belfast_Router
ip cef
no ipv6 cef
license udi pid CISCO2911/K9 sn FTX15247LB2-
 encr aes
 group 5
crypto isakmp key cisco address 149.153.1.2
crypto ipsec transform-set BelfastCarlow_Set esp-aes esp-sha-hmac
crypto map BelfastCarlow_Map 102 ipsec-isakmp
 set peer 149.153.1.2
 set transform-set BelfastCarlow_Set
 match address 102
interface Loopback0
 ip address 3.3.3.3 255.255.255.255
interface Tunnel0
 ip address 172.16.250.2 255.255.255.252
 mtu 1476
 tunnel source Serial0/0/1
 tunnel destination 149.153.1.2
 no ip address
 ip nat inside
 duplex auto
 speed auto
 ip address 10.100.2.1 255.255.255.224
 ip nat inside
 ip address 10.100.2.33 255.255.255.224
 ip nat inside
 ip address 10.100.2.65 255.255.255.224
 ip nat inside
 ip address 10.100.2.97 255.255.255.240
 ip nat inside
 ip address 10.100.2.113 255.255.255.248
 ip nat inside
 ip address 10.100.2.121 255.255.255.248
 ip nat inside
 no ip address
 duplex auto
 speed auto
 shutdown
 no ip address
 duplex auto
 speed auto
 shutdown
 no ip address
 clock rate 2000000
 shutdown
 ip address 149.153.1.6 255.255.255.252
 clock rate 2000000
interface Vlan1
 no ip address
 shutdown
router ospf 1
 router-id 3.3.3.3
router ospf 2
ip classless
ip route 0.0.0.0 0.0.0.0 149.153.1.5
line con 0
line aux 0
line vty 0 4
 login
end
5 Replies 5
georgehewittuk1
I only have a minute to reply saw your post and thought i could help.
First of all i would opt for protecting the GRE tunnel with IPSEC all in the same configuration so anything that goes over the tunnel is encrypted.
https://networklessons.com/cisco/ccie-routing-switching-written/ipsec-static-virtual-tunnel-interface
Second of all for your issues looks like you are not accounting for the fact in the IPSEC crypto ACL that the traffic will be matching the GRE tunnel source <-> destination not the LAN traffic.
George
if this is a Packet Tracer project, post the zipped project (.pkt) file...
I have left the zip below!
what instructions are you following ? You have legacy crypto maps, tunnel interfaces, OSPF, static routes and partial NAT all mixed up.
in any case, the access lists for the crypto map are wrong. They need to be:
Carlow_Router
access-list 102 permit ip 10.100.0.0 0.0.0.255 10.100.2.0 0.0.0.255
Belfast_Router
access-list 102 permit ip 10.100.2.0 0.0.0.255 10.100.0.0 0.0.0.255
