QoS with Ephemeral port
cecilmayy
If my ACL for QoS is: example
ip access-list extended SET-AF41
 remark High Pri
 permit tcp any any eq 80
class-map xxxx match access-list extended SET-AF41
set af41
1. TCP Ephemeral Source Port 32222, Destination Port 80. Matches the ACL and MARKED packet as AF41
2. Return Packet is destination port 32222
3 How does the returning router knows that the returning packet should be marked AF41?
Note: ignore some of the commands - Just looking for the concept on how the returning router keeps track of QoS returning packet DSCP value.
5 Replies 5
Jon Marshall
As far as I know it doesn't ie. QOS is not stateful and the router does not keep track of connections in the way a firewall would.
If you want QOS on the return path you would need configure that as well.
Jon
Jon,
I don't think this ACL will make any difference,  Maybe NBAR will or a different ACL with source IP and destination without ports numbers on both ends. Although it will be wide open.
 remark High Pri
 permit tcp any any www
I don't really understand what you are saying.
As I said if you want QOS for the return path you need to configure it.
Jon
Thanks for your time, Jon.
What I meant to say is that its difficult to craft and return Http/https return packet ACL because the return packet will have random ports as it destination ports (1024–65535)
 remark High Pri
30 permit tcp host Server_IP_address  host Client IP_Address range 1024–65535 (something like this on return RTR) Not sure if it's scalable. I got the concept.
Thank you,
Jon
Joseph W. Doherty
"3 How does the returning router knows that the returning packet should be marked AF41?"
remark High Pri
permit tcp any eq 80 any !normally, return http traffic would have 80 as source port
