Help With HSRP
kelvinboar
Hopefully someone can help me here
I have 2x3945 routers i'm trying to get HRSP to work on. The configuration looks fine & i can see the active & standby router. But when i pull the cable the standby router first changes to active as it should, but then the interface shuts & then HSRP goes into the init state?? has anyone ever had this before? I have double checked my config of an old 3745 & worked fine. And i have set up our new 3750 switches with HSRP & they work fine. But no matter what i do on the new 3945's once that interface shuts HSRP stops working, which sort of defeats the object of HSRP.
Thanks in advance
20 Replies 20
kolhausen
Do you have an example of your interface configuration?
yeah sure
Router#sh int g 0/2
GigabitEthernet0/2 is up, line protocol is up
  Hardware is PQ3_TSEC, address is c89c.1dc6.9e82 (bia c89c.1dc6.9e82)
  Internet address is 192.168.0.3/24
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive set (10 sec)
  Full Duplex, 1Gbps, media type is RJ45
  output flow-control is XON, input flow-control is XON
  Last input 00:00:00, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 7000 bits/sec, 9 packets/sec
  5 minute output rate 7000 bits/sec, 10 packets/sec
     85665 packets input, 7628397 bytes, 0 no buffer
     Received 85665 broadcasts (0 IP multicasts)
     0 watchdog, 85553 multicast, 0 pause input
     87952 packets output, 7799777 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     0 unknown protocol drops
     3 lost carrier, 0 no carrier, 0 pause output
hi kelvin,
kindly post your running config both on your 3945s and also the show standby command output for us to check.
HI
@ johnlloyd_13
I will have to do this monday now as it's now the weekend here. But will post everthing first thing monday morning. Thanks in advance
Kelvin
Here is the running config & sh standby for both routers.
R1#sh run
Building configuration...
Current configuration : 1303 bytes
! Last configuration change at 23:02:33 UTC Sun Mar 27 2011
version 15.1
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
license udi pid C3900-SPE150/K9 sn
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
ip address 192.168.0.2 255.255.255.0
duplex auto
speed auto
standby version 2
standby 1 ip 192.168.0.1
standby 1 timers msec 100 msec 300
standby 1 priority 105
standby 1 preempt
interface FastEthernet0/0/0
interface FastEthernet0/0/1
interface FastEthernet0/0/2
interface FastEthernet0/0/3
interface FastEthernet0/1/0
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface Vlan1
no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
R1#sh stan
R1#sh standby
GigabitEthernet0/2 - Group 1 (version 2)
  State is Active
    18 state changes, last state change 00:10:51
  Virtual IP address is 192.168.0.1
  Active virtual MAC address is 0000.0c9f.f001
    Local virtual MAC address is 0000.0c9f.f001 (v2 default)
  Hello time 100 msec, hold time 300 msec
    Next hello sent in 0.016 secs
  Preemption enabled
  Active router is local
  Standby router is 192.168.0.3, priority 100 (expires in 0.240 sec)
  Priority 105 (configured 105)
  Group name is "hsrp-Gi0/2-1" (default)
R1#
R2#sh run
Current configuration : 1289 bytes
! Last configuration change at 23:02:42 UTC Sun Mar 27 2011
version 15.1
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
no ip domain lookup
no ip address
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
ip address 192.168.0.3 255.255.255.0
duplex auto
speed auto
standby version 2
standby 1 preempt
--More--
interface Vlan1
no ip address
no ip http server
control-plane
line con 0
line aux 0
line vty 0 4
login
transport input all
end
R2#sh stan
R2#sh standby
  State is Standby
    25 state changes, last state change 00:00:05
    Next hello sent in 0.048 secs
  Preemption enabled
  Active router is 192.168.0.2, priority 105 (expires in 0.320 sec)
    MAC address is 6400.f103.cc82
  Standby router is local
  Priority 100 (default 100)
R2#
johnlloyd_13
Level 9
Level 9
Your config looks ok. Could you give us a brief description or a diagram of your HSRP setup? What interface that was shutdown? Is it on the LAN or WAN side? You may want to tweak your timers. The ms timers might be too fast for HSRP to capture the 3rd hello. Also try to add a preempt delay timer and test again.
At the minute (as this is in the testlab) I just have to 2 routers connected by a single gig port. So G 0/2 on R1 connects to G 0/2 R2. I'll slow the timers down and try again, but this is an emergency call centre so timers will have to be fast.
Here's the out put of what happens.
R1#
*Mar 28 03:47:29.856: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/2, changed state to down
*Mar 28 03:47:30.856: %LINK-3-UPDOWN: Interface GigabitEthernet0/2, changed state to down
*Mar 28 03:47:30.856: %HSRP-5-STATECHANGE: GigabitEthernet0/2 Grp 1 state Active -> Init
R1#
R2#
*Mar 28 03:48:54.790: %HSRP-5-STATECHANGE: GigabitEthernet0/2 Grp 1 state Standby -> Active
*Mar 28 03:48:57.182: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/2, changed state to down
*Mar 28 03:48:58.182: %LINK-3-UPDOWN: Interface GigabitEthernet0/2, changed state to down
*Mar 28 03:48:58.182: %HSRP-5-STATECHANGE: GigabitEthernet0/2 Grp 1 state Active -> Init
As you can see this happens when G 0/2 goes down (like if R1 went down). And the standby router kicks in for a few seconds, so i think the timers are ok. But i will double check & confirm.
Just reconfigured the hello & hold down timers to 1sec & 3sec. This time the standby didn't even make it to the active state, went standby to Init??
Make the other router as active and then pull the cable of standby... check whats the result you get. Did you try with HSRP version 1? Also a network diagram could make things easier to understand.. Is it possible for you to send the network diagram and "sh interfaces" of both routers?
On the previous devices on which it was working fine... were they working with version 2 or version 1 of HSRP?
Talha
I have had both routers as active & standby with the same result, neither worked. Yep tried Version 1 same result. I have uploaded a diagram but as you'll see at the minute it's just 2 routers connected by gig ports & a cat 5 cable.
Here is the Int out put of the 2 interfaces
R1#sh int g 0/2
  Hardware is PQ3_TSEC, address is 6400.f103.cc82 (bia 6400.f103.cc82)
  Internet address is 192.168.0.2/24
     307837 packets input, 28576817 bytes, 0 no buffer
     Received 307837 broadcasts (0 IP multicasts)
     0 watchdog, 307713 multicast, 0 pause input
     311654 packets output, 28830400 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     8 lost carrier, 0 no carrier, 0 pause output
R1#
R2#en
R2#sh int g 0/2
  5 minute input rate 1000 bits/sec, 1 packets/sec
  5 minute output rate 1000 bits/sec, 1 packets/sec
     172993 packets input, 16340130 bytes, 0 no buffer
     Received 172993 broadcasts (0 IP multicasts)
     0 watchdog, 172906 multicast, 0 pause input
     175118 packets output, 16458914 bytes, 0 underruns
     1 unknown protocol drops
R2#
Not sure what else to try??
hi kelvin,
looking at your setup, i would suggest to add a LAN switch and a client and do your failover test again.
Hope you have the below scenorio testing in your lab environmet, right??
|--------------| Gi0/2         Gi 0/2|-----------------|
|    R1      |------------------------|       R2      |
|________|                        |__________|
Now, my questions are
     1. Is this the setup you are using in your scenorio??
     2. Do you have any other connectivity b/w R1 & R2?
If this is the only connectivity b/w R1 & R2 and when you unplug the connectivity between the two routers then none of the routers will become hsrp active as the the link for hsrp connectivty itself is down.
HTH,
Bava
@bava_ccna
That's correct. Simple setup & HSRP fails when the cable is pulled.
Hello Kelvin,
This is the expected behaviour of HSRP. Simple, you have unplugged the connectivity b/w the routers, then how come the hsrp hello messages reach each other??
HTH,
Bava
