Hiding Router on internet by dropping as opposed to denying packets
ManIDE661
Im' trying to hide my router from the internet by having all unwanted requests producing a timeout to the intruder.
I have added access lists to block incoming connection requests.
e.g:  "deny   tcp any any eq telnet log"
I have also added to all my  vty " transport input none"
This is working.
my problem is when someone tries to connect from outside  (internet)  the router denies the request with the result of them seeing  a "Connection refused" message at their end
What I want is nothing to be sent just a timeout should result to any of these packet requests , It that possible ?
Manuel.
13 Replies 13
balaji.bandi
I would suggest to move to Telnet to SSH, Telnet is not secure.
I would advise why not use source interface. so other interface not part of it ? (is this workable ?) or you still need outside access ?
(config)#ip ssh source-interface ?
  Async               Async interface
  Auto-Template       Auto-Template interface
  BVI                 Bridge-Group Virtual Interface
  CDMA-Ix             CDMA Ix interface
  CTunnel             CTunnel interface
  Dialer              Dialer interface
  FastEthernet        FastEthernet IEEE 802.3
  GMPLS               MPLS interface
  GigabitEthernet     GigabitEthernet IEEE 802.3z
  LISP                Locator/ID Separation Protocol Virtual Interface
  Lex                 Lex interface
  LongReachEthernet   Long-Reach Ethernet interface
  Loopback            Loopback interface
  MFR                 Multilink Frame Relay bundle interface
  Multilink           Multilink-group interface
  Null                Null interface
  Port-channel        Ethernet Channel of interfaces
  Serial              Serial
  Tunnel              Tunnel interface
  Vif                 PGM Multicast Host interface
  Virtual-Dot11Radio  Virtual dot11 interface
  Virtual-PPP         Virtual PPP interface
  Virtual-Template    Virtual Template interface
  Virtual-TokenRing   Virtual TokenRing
  vmi                 Virtual Multipoint Interface
BB
Hi.
Yes this a home office.
I don't need to access the router from outside or inside with telnet or SSH.
I would like to hide the router.
when I try and telnet into this router I get a "connection refused",    just to be clear I don't need telnet or SSH access into this router from anywhere I'm just trying to explain the result of the telnet attempt.
My ISP suppled router   resulted in a time out when trying to Telnet or SSH into that router.
and I want my cisco router to do the same.
If you remove SSH, how will you manage the device ? Console ?
post show run to look what you got it.
BB
which router model do you have ? I don't think the 'Connection Refused' response is generated on the router, but rather on the client.
There is a global command 'ip telnet quiet', you might want to check if that is available in your IOS version, and what that results in...
I think the client saying 'connection refused' is generated by an ICMP unreachable from the target device. I think the command that would do what the OP is describing is the interface level command here.
no ip unreachables
 Connection refused is the result of an explicit response from the target device. If it just fails, that would generate a 'connection timeout' type response.
ManIDE661
I was using a friends laptop for testing it looks that this message  "connection refused" was his client. as indicated above
I have loaded putty now and we get  "connection times out"  for telnet connections
I have a cisco 1941 running   ISO 158-3.M3.
we only be configuring via the Console port on this router.
Im still having issues with ftp and SSH  Replies messages.
ftp gives "connection closed by remote host"  (ftp from the command prompt).
ssh  gives "remote side unexpectedly closed network connection"  (from putty).
Is there a way I can stop these messages?
Here is my run config of interest
aaa new-model
ip inspect WAAS flush-timeout 10
ip cef
login on-failure log
login on-success log
no ipv6 cef
interface Dialer1
 mtu 1492
 ip address negotiated
 ip access-group No-PING in
 ip access-group 198 out
 no ip unreachables
 ip nat outside
 encapsulation ppp
 ip tcp adjust-mss 1452
 dialer pool 1
 no cdp enable
ip access-list extended No-PING
 permit icmp any any echo-reply
 deny   icmp any any
 deny   tcp any any eq www log
 permit ip any any
ip access-list extended TRACERT
 permit icmp any any traceroute
access-list 198 permit ip any any
control-plane
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line 0/0/0
 script dialer hspa-R7
 modem InOut
 no exec
 transport input all
 rxspeed 21600000
 txspeed 5760000
line 0/0/1
 no exec
line vty 0 4
line vty 5 15
I don't see exactly where it is failing, but you can tell if it is an ACL if you add the keyword "log" at the end of any "deny" statements. Unless you have a "permit any any" at the end of an ACL, you should use an explicit deny all at the end with the "log" keyword instead of accepting the implicit deny all the end.
I have followed up with more testing of my issues and this is what i found.
using the command
no ip unreachables
It provides a time out as needed.
however this is limited to entries in my Access-list.
permit icmp any any echo-reply log
deny   icmp any any log
deny   tcp any any eq 21 log
permit ip any any
eg If i telnet  on ports 20,21,22   I get the "Connection Time Out" message
when i telnet on port 45734 (as an example)  i get "connection refused/denied"  and no log message is produced.
@Elliot Dierksen I tried using  an explicit deny all at the end of my access list before the  "permit ip any any".
I added  deny   tcp any any  log But this failed as i lost connectivity.
My issues at present are
1) What should that explicit deny look like, (to show other telnet ports)?
2) Where are those telnet requests be getting refused if not in my Access-list?
M.
which IOS version are you running ? Check if your IOS supports the Zone Based Firewall:
1941#conf t
1941(config)#zone ?
Is that command available ? If so, post the full running config of your router, so we can fill in the bits and pieces...
Yes I have the Zone command   Ver15.8
That is part of the mixed bag that is "no ip unreachable". A connection to router where no service is listening would generate a "port unreachable" ICMP message, but the "no ip unreachable" turns that off.
ManIDE661
Hello.
Below is my config I am using the "no ip unreachables"  In my set up, is it in the correct location ?
I have "ip telnet quiet"  added as suggested but not sure its doing anything  in my setup.
version 15.8
boot-start-marker
boot system flash0:c1900-universalk9-mz.SPA.158-3.M3.bin
boot-end-marker
aaa new-model
aaa local authentication attempts max-fail 8
aaa authentication login default local
aaa session-id common
ip dhcp excluded-address 192.168.1.1 192.168.1.100
ip dhcp excluded-address 192.168.10.1 192.168.10.100
ip dhcp pool LAN
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 192.168.1.1
ip dhcp pool WLAN
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
ip cef
no ipv6 cef
chat-script hspa-R7 "" "AT!SCACT=1,2" TIMEOUT 60 "OK"
crypto pki certificate chain TP-self-signed-8887778887
certificate self-signed 01
quit
license udi pid CISCO1941/K9 sn FGL
redundancy
notification-timer 120000
controller Cellular 0/0
gsm modem crash-action boot-and-hold
track 1 ip sla 1 reachability
ip telnet quiet
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description WLAN uplink port
ip address 192.168.10.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1/0
description WAN Uplink
switchport mode trunk
no ip address
interface GigabitEthernet0/1/1
no ip address
interface GigabitEthernet0/1/2
no ip address
interface GigabitEthernet0/1/3
no ip address
interface GigabitEthernet0/1/4
no ip address
interface GigabitEthernet0/1/5
no ip address
interface GigabitEthernet0/1/6
no ip address
interface GigabitEthernet0/1/7
no ip address
interface Cellular0/0/0
description 3G Link to Vodafone-AP
ip nat outside
encapsulation slip
dialer in-band
dialer string hspa-R7
dialer-group 2
async mode interactive
interface Cellular0/0/1
no ip address
encapsulation slip
interface Vlan1
description LAN
ip nat inside
interface Vlan100
description WAN
no ip address
ip nat outside
pppoe enable group global
pppoe-client dial-pool-number 1
interface Dialer1 REM this is the main interface  for data
mtu 1492
no ip unreachables
ip nat outside
ip virtual-reassembly in max-fragments 16 max-reassemblies 64 timeout 5
encapsulation ppp
dialer pool 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname secret.user@one.com
ppp chap password 0 cisco123
ppp pap sent-username secret.user@one.com 0 cisco123
ppp ipcp dns request
ppp ipcp route default
ip local policy route-map track-primary-if
ip forward-protocol nd
ip dns server queue limit forwarder 8
ip dns server
ip nat inside source route-map nat2backup interface Cellular0/0/0 overload
ip nat inside source route-map nat2primary interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1 track 1
ip route 0.0.0.0 0.0.0.0 Cellular0/0/0 253
deny icmp any any
deny tcp any any eq ftp log
deny tcp any any eq 22 log
deny tcp any any eq login log
permit ip any any
ip sla 1
icmp-echo 8.8.8.8 source-interface Dialer1
ip sla schedule 1 life forever start-time now
logging host 192.168.1.254
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
route-map track-primary-if permit 1
match ip address 197
set interface Dialer1
route-map nat2primary permit 1
match ip address 198
match interface Dialer1
route-map nat2backup permit 1
match interface Cellular0/0/0
access-list 197 permit icmp any host 8.8.8.8
control-plane
line con 0
line aux 0
line 2
no exec
stopbits 1
line 0/0/0
modem InOut
no exec
transport input all
rxspeed 21600000
txspeed 5760000
line 0/0/1
no exec
line vty 0 4
line vty 5 15
scheduler allocate 20000 1000
ntp server 0.au.pool.ntp.org
ntp server 2.au.pool.ntp.org
ntp server 1.au.pool.ntp.org
ntp server 3.au.pool.ntp.org
Connection timeouts when you have ip unreachables enabled on the relevant interface is expected behavior. I haven't used "ip telnet quiet" before, so I can't speak to that. If Dialer0 is your WAN interface then I would say you have it in the right place. Even though Cellular0 is the physical interface associated with this, I think the only interface that will have an IP is Dialer0. I mention that because of the "ip route 0.0.0.0 0.0.0.0 Cellular0/0/0 253" command. I doubt that is hurting anything, but I don't think it would do anything either.
