high cpu temperature 76 degree celsius
sebastianlux
I have a Cisco 2921 Router with actually no clients working on it but the CPU temperature is 76 degree celsius. Is this normal? I think this is too hot.
My room is aircondishened to 21 degree celsius. What can I do?
Thanks a lot
Sebastian
5 Replies 5
paolo bevilacqua
Include the complete "show environment".
That Iwill tell you if the values are normal or not.
seems a bit high but depends on cpu load, what is the speed of the fans?
My 2921 is humming around @ 20-30% cpuload and look fine.
SYSTEM FAN STATUS
Fan 1 OK, Low speed setting
Fan 2 OK, Low speed setting
Fan 3 OK, Low speed setting
Fan 4 OK, Low speed setting
SYSTEM TEMPERATURE STATUS
Intake Left temperature: 21 Celsius, Normal
Intake Right temperature: 17 Celsius, Normal
Exhaust Left temperature: 22 Celsius, Normal
Exhaust Right temperature: 20 Celsius, Normal
CPU temperature: 48 Celsius, Normal
Power Supply Unit temperature: 19 Celsius, Normal
cpu util is almost 0%
SYSTEM FAN STATUS
Intake Right temperature: 20 Celsius, Normal
Exhaust Left temperature: 34 Celsius, Normal
Exhaust Right temperature: 27 Celsius, Normal
CPU temperature: 76 Celsius, Normal
Power Supply Unit temperature: 23 Celsius, Normal
You can try updating IOS.
Thanks Paolo,
but well, I think 76 celsius is not normal especially with 0% load... maybe upgrading could solve the problem. does somebody has any other idea?
