11-22-2021 11:11 PM
High CPU spikes occurred occasionally on C881-K9 router. After checked, the high cpu usage is caused by SNMP ENGINE. Does anyone know why SNMP ENGINE cause the high cpu usage and how to fix it?
Thank you.
CPU utilization for five seconds: 99%/0%; one minute: 19%; five minutes: 14%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
2 127092 929778 136 0.00% 0.01% 0.00% 0 Load Meter
6 8678540 873029 9940 0.00% 0.17% 0.16% 0 Check heaps
13 2288360 77438 29550 0.00% 0.03% 0.00% 0 Licensing Auto U
36 14276 4810310 2 0.08% 0.00% 0.00% 0 ARP Background
83 979432 81544 12011 0.00% 0.01% 0.00% 0 BGP Scanner
95 109816584 22922559 4790 1.49% 2.63% 2.69% 0 COLLECT STAT COU
99 323680 559037246 0 0.00% 0.12% 0.14% 0 Ethernet Msec Ti
117 144360 68886047 2 0.08% 0.03% 0.02% 0 VRRS Main thread
133 139424 135122810 1 0.00% 0.02% 0.01% 0 IPAM Manager
137 3310844 25594453 129 0.08% 0.18% 0.13% 0 IP Input
155 746352 15529026 48 0.00% 0.01% 0.00% 0 Spanning Tree
270 138064 68886040 2 0.00% 0.03% 0.02% 0 MMA DB TIMER
274 16312 8917272 1 0.08% 0.00% 0.00% 0 Timer Library
308 137348 68886030 1 0.00% 0.02% 0.01% 0 PERFMON ASYNC TI
309 139604 68886066 2 0.00% 0.03% 0.02% 0 MMA DP TIMER
320 512252 3869820 132 0.00% 0.03% 0.02% 0 Crypto IKMP
351 4728 968 4884 0.00% 0.70% 0.69% 10 SSH Process
393 1298212 203430 6381 0.00% 0.01% 0.00% 0 Per-minute Jobs
394 117752 4649541 25 0.08% 0.02% 0.00% 0 Per-Second Jobs
410 365588 276458667 1 0.00% 0.09% 0.08% 0 HSRP Common
412 255588 136364575 1 0.00% 0.06% 0.07% 0 PPP manager
413 203376 136364656 1 0.00% 0.04% 0.05% 0 PPP Events
420 878272 1059338468 0 0.00% 0.44% 0.47% 0 IP SLAs XOS Even
421 849088 1059232009 0 0.08% 0.42% 0.46% 0 IP SLAs Control
422 989804 1059755599 0 0.00% 0.44% 0.46% 0 IP SLAs Responde
423 715292 3558863 200 0.00% 0.01% 0.00% 0 IP SNMP
425 326368148 3761790 86761 97.08% 12.60% 7.96% 0 SNMP ENGINE
11-22-2021 11:31 PM
Restart the SNMP process and see if the CPU utilization drops.
11-22-2021 11:59 PM
Hi Leo,
Thanks for suggestion. The high CPU usage occurred randomly, occasionally and only keeping high for a few seconds. I wonder if it is a problem or not.
1111111111111111111111333339999966666
220000000000555552222288888999992222288888666666666655555555
100 *****
90 *****
80 *****
70 *****
60 **********
50 **********
40 ***************
30 ***************
20 ***** ***************
10 ************************************************************
0....5....1....1....2....2....3....3....4....4....5....5....6
0 5 0 5 0 5 0 5 0 5 0
CPU% per second (last 60 seconds)
11-23-2021 12:17 AM
Please post the complete output to the command "sh version".
11-23-2021 12:25 AM
11-23-2021 01:34 AM - edited 11-23-2021 01:39 AM
Please post the complete output to the command "sh snmp". NOTE: Remove private information if possible.
Kindly have a look at CSCta43825.
11-22-2021 11:47 PM
for testing remove the SNMP config and check is that better, also check any new IOS available to upgrade,
11-23-2021 12:38 AM
the reason could be a certain MIB being polled. Turn on SNMP debugging (debug snmp) and check which MIBs are being polled.
Also, have a look at the document linked below:
