how to reduce timing in bgp load Balancing or Transferring
damcotech
How to reduce timing in BGP load balancing or transferring. When my primary ISP goes down, it getting 60 Sec timing to transfer with other ISP. Kindly suggest how can I reduce this timing in BGP settings.
Mukesh
JohnTylerPearce
Level 7
Level 7
Annu,
The default Holdtime for BGP is 60 seconds with the Dead Time being 3x(Hello) so 180 seconds by default or 3 minutes.
I would do the following.
1. Reduce the keepalive/holddown time to a smaller number (Not to small, to that you have lots of flaps due to this)
2. Implement BFD.
Hi Mukesh,
Considering BFD is a good option.
As John mentioned if we modify the timers without proper study if yout network it might lead to flaps. I have seen people using hello/hold timer of 1/3 with BGP and complaining about flaps.
Take a look at BGP PIC for IP/MPLS and see if it can help you. But I believe it is available on high end platforms.
http://www.cisco.com/en/US/docs/routers/7600/ios/15S/configuration/guide/BGP.html
Madhu
daniel.dib
Level 7
Level 7
The others have given you good suggestions. I would just like to mention that any network convergence event is heavily dependant on getting link down on the interface.
If you get link down on the interface then the next-hop would be invalid and convergence can take place and install other routes into RIB/FIB.
How are you connected to the ISP?
Daniel Dib
CCIE #37149
Please rate helpful posts.
Daniel Dib
CCIE #37149
CCDE #20160011
