04-26-2017 09:16 AM - edited 03-05-2019 08:25 AM
Dear All,
Please I need your assistant on the scenario below.
We have a company (A) that is working with my company (b) and another company (c).
I have decided to represent them with 3 router named Router A, B,C as depicted in the attached image .
Router A belong to company A, Router B belong to company B and Router C belong company.
All the 3 routers are connected to internet cloud.
Connection between Router C and any other routers must be via VPN but for the reasons best known to my company they do not want Router A to have direct VPN connection with Router C, they want Router A to connect to my company's router (Router B) then Router B forward the traffic to Router C.
My challenge is how can i achieve this scenario.
Thanks in anticipation of your favourable reply.
Timothy
04-26-2017 09:34 AM
Router B acts as a transit router for routers A and C.
Is there some complexity I'm overlooking?
04-27-2017 07:55 AM
As Joseph said, you can just have Router B act as a transit router. You will just need to make sure that Router C learns Router A's network. Preferably via a dynamic routing protocol. And that should be about it.
