Radius configuration on Nexus 7k
niterid3r
Has anyone experienced configuring radius authentication on Nexus 7k?
Any issues with it. I have heard once you have configured the radius you are only able to run show commands on it.
Can anyone please paste the sample configuration in used by someone.
Thanks.
niterid3r
Radius Server is Steel Belted V 6.X
I have the same issue with Nexus100v. As a user i can successfully authenticate however the level of privilidges is pretty much restricted to ping and traces. We are using Windows Server 2003r2, my same user and password are fine for Catalyst based switches. Configuration as follows, any help would be greatly appreciated.
aaa authentication login console group radius local
aaa group server RadServer
server 172.a.b.c
use vrf management
source-interface mgmt0
radius-server host 172.a.b.c key XXXXXX authentication
Darren
I had the same issue. The issue is with your Radius authentication server. IT needs to pass back to the Cisco device the login level. check out this article. It helped me fix my issue.
http://blog.skufel.net/2012/06/how-to-integrating-cisco-devices-access-with-microsoft-npsradius/
