How can test the - PairGain HDSL HiGain ETSI...?
sugar2ferret
hi yesterday i have a big headache triying to connect a E1 (its a full duplex 2 mbps link) with this modem: PairGain HDSL HiGain ETSI with a Cisco 1841 for a friend in Mexico, it was like impossible for me to accomplish that it was really ftrustrating, i cant ping my serial interfase from the ethernet interface of the cisco, i cant test if the PairGain were able to work fine, i dont know if the PairGain has a console access as the cisco console for administration, configuring or testing suite. I need an advice of how can i do it guys.
Thanks in advance and i attach here my config file:
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname EHVGEM
boot-start-marker
boot-end-marker
security authentication failure rate 10 log
security passwords min-length 6
logging buffered 4096 debugging
logging console critical
enable secret xxxx
enable password xxxx
aaa new-model
aaa authentication login local_auth local
aaa session-id common
resource policy
clock timezone PCTime -7
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
no ip source-route
no ip gratuitous-arps
ip cef
no ip bootp server
no ip domain lookup
ip domain name yourdomain.com
ip name-server 200.x.x.1
login block-for 3 attempts 3 within 3
username xxx privilege 15 secret xxxx
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$
ip address 200.130.x.x.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
shutdown
speed auto
half-duplex
no mop enabled
interface FastEthernet0/1
ip address 192.168.101.210 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
shutdown
duplex auto
speed auto
no mop enabled
interface Serial0/0/0
ip address 200.23.x.x.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
shutdown
clock rate 2000000
router rip
redistribute connected
network 10.0.0.0
network 200.x.101.0
network 200.x.237.0
ip route 0.0.0.0 0.x.x.x.23.251.201
ip http server
ip http authentication local
ip http timeout-policy idle 5 life 86400 requests 10000
ip access-list extended autosec_complete_bogon
etc. etc......
permit ip any any
logging trap debugging
logging facility local2
access-list 100 permit udp any any eq bootpc
access-list compiled
dialer-list 1 protocol ip permit
no cdp run
control-plane
banner login C
Cisco Router and Security Device Manager (SDM) is installed on this device. This
feature requires the one time use, initial credentials, of username "cisco"
with password "cisco".
Please change these publicly known initial credentials through SDM or IOS CLI.
Here's the Cisco IOS command:
no username cisco
NOTE: Please add a new username to be able to launch SDM for router management.
For more information about SDM please follow the instructions in the QUICK
START GUIDE for your router or at
http://www.cisco.com/go/sdm
banner motd C EHV-GEM Authorized Use
line con 0
exec-timeout 5 0
login authentication local_auth
transport output telnet
line aux 0
exec-timeout 15 0
line vty 0 4
privilege level 15
password xxxx
transport input telnet
line vty 5 15
privilege level 15
password xxxx
scheduler allocate 20000 1000
end
mastram4u
I think pairgain modem has console access and also the front panel display.
Have you checked up the local loop back given from the modem and check if you are able to ping your own IP address on the serial port?
And in the configuration pasted, why is the serial interface in shutdown condition?
Hello friend,
I was looking for and I talked to ISP staff. They told me the PairGain HDSL modem is managed remotely from ISP, so you´ll have to phone them.
