How do determine which pc's are using up the wan bandwidth ?
anand.narine1
Please see the attached screenshot., how do i go about this?
i would go closest to the source of the traffic. So, Router 1 at the client side.
anand.narine1
Suppose I have:
  Clients -------- switch-------router--------router----------router (netflow enabled) ---------switch---------Servers
In  the above topology with netflow only enbled in the last router. Will i  still be able to monitor which clients are using up bandwidth to the  Servers? Or should I enable netflow on the first router?
serge123
You could configure under the interface
Show ip accounting to check the result
