Ospf or eigrp for large networks
carl_townshend
Hi all
For large networks, what are people’s preferences for a routing protocol out of ospf or eigrp.
I have always thought ospf as is scales better.
cheers
5 Replies 5
as a rule of thumb, EIGRP converges faster than OSPF, but OSPF indeed scales better.
Have a look at the comparison link below:
https://community.fs.com/blog/eigrp-vs-ospf-differences.html#:~:text=OSPF%20scales%20better%20than%20EIGRP,IGP%20(Interior%20Gateway%20Protocol).
balaji.bandi
EIGRP (more of cisco prop) - people now accepting other vendors not majorly
OSPF - Open Standard with other vendors. widely popular.
EIGRP vs OSPF you can use depends on the use case. ( some is OSPF does equal-cost path, EIRGP do unequal) - so while designing we need to consider the pros and cons.
BB
Hello
OSPF isnt proprietary so it does indeed scale a lot better as its an open standard protocol - EIGRP isnt its ciscos own routing protocol and I would say it is better on a pure cisco envronment than OSPF and lasty I think ive read somewhere its wont be proprietary in the future.
Kind Regards
Paul
Joseph W. Doherty
Perhaps the biggest deciding factor is often what a particular shop is already using or familiar with.  Most will continue to use what they know.  Further, if a shop changes their primary routing protocol, they often lack experience to do it "right", especially large scale, since they don't really know what they don't know.
When trying to decide which to use, above and beyond the forgoing, it really depends, firstly, whether you want to be "locked in" to using Cisco devices, as EIGRP is, or was (Cisco has released some of EIGRP for other vendor usage, but I believe not all of it), proprietary.  Not using EIGRP does put you into a much better bargaining position.
As to scalability, not really a huge difference, just how you do it varies between the two.  With OSPF you use areas and with EIGRP you (as I understand it) use summarization.
As to convergence speed EIGRP has a slight edge over OSPF, but both can be configured/tuned (at least on Cisco devices) to generally obtain subsecond convergence.
Also on the subject of Cisco devices, Cisco's OSPF implementation is often much (much) better than many other Brand X vendors.  (When you can use Brand X for half the price, different parties will often want you to do so.  However, you'll may then discover why Brand X is half the price.)
Hub and spoke the best is EIGRP
inside SP core OSPF
campus EIGRP or OSPF
