05-16-2022 11:53 PM
Hello everyone,
I need a very specific answer about how egress PE processes the VPN label and get the correct VRF so afterwards it will do another IP lookup for the destination IP address.
Assuming Per-VRF VPN label allocation.
Which table or which decoding method the PE does for the VPN label to get the correct VRF that the traffic destined to it.
Solved! Go to Solution.
05-17-2022
07:53 AM
- last edited on
05-20-2022
05:49 AM
by
Translator
Hi @Mustafa Nassef ,
With per-vrf label allocation, an aggregate label will be installed in the LFIB. When a packet is received with that label, the label is removed and the IP packet is looked up against the appropriate VRF table. Packets are then forwarded accordingly.
RP/0/0/CPU0:PE1#sh mpls for
Tue May 17 15:02:02.606 UTC
Local Outgoing Prefix Outgoing Next Hop Bytes
Label Label or ID Interface Switched
24000 Pop 192.168.100.3/32 Gi0/0/0/1 192.168.23.3 7174
24002 24001 192.168.100.4/32 Gi0/0/0/1 192.168.23.3 10752
24003 Aggregate test: Per-VRF Aggr[V] \test 520
RP/0/0/CPU0:PE1#
05-17-2022 12:00 AM
check this document may help you understand:
https://www.ciscopress.com/articles/article.asp?p=1081501&seqNum=4
05-17-2022 12:18 AM
Thank you for your reply.
This document assumes the other option of VPN label allocation (Per-prefix) as follows:
"Then PE2 looks up the inner label 3333 in the LFIB, noting the pop action as well, along with the outgoing interface. So PE2 forwards the unlabeled packet out interface S0/1/0."
What I was asking about was the other approach of Per-VRF allocation in which the whole VRF including all its routes are assigned to one VPN label.
05-17-2022
03:33 AM
- last edited on
05-20-2022
05:48 AM
by
Translator
you config RT under VRF
any VPNv4 from other MP-iBGP or MP-eBGP have RT with prefix
the router do filter
RT import same MP-iBGP MP-eBGP RT <- prefix use
RT import not same MP-iBGP MP-eBGP RT <- prefix NOT use
05-17-2022 07:05 AM
Thanks for your reply.
What you are mentioning is the control plane and what I asked for was data plane. Traffic forwarding not updates exchanging process.
05-17-2022 07:46 AM - edited 05-17-2022 12:30 PM
this answer is correct, please find below comment
05-17-2022
07:53 AM
- last edited on
05-20-2022
05:49 AM
by
Translator
RP/0/0/CPU0:PE1#
05-20-2022 04:16 AM
Thank you so much, you hit the nail on the head.
05-17-2022 08:15 AM - edited 05-17-2022 08:15 AM
This is the packet-forwarding process in a multi-VRF-CE-enabled network:
When the switch receives a packet from a VPN, the switch looks up the routing table based on the input policy label number. When a route is found, the switch forwards the packet to the PE.
When the ingress PE receives a packet from the CE, it performs a VRF lookup. When a route is found, the router adds a corresponding MPLS label to the packet and sends it to the MPLS network.
When an egress PE receives a packet from the network, it strips the label and uses the label to identify the correct VPN routing table. Then it performs the normal route lookup. When a route is found, it forwards the packet to the correct adjacency.
When a CE receives a packet from an egress PE, it uses the input policy label to look up the correct VPN routing table. If a route is found, it forwards the packet within the VPN.""
05-20-2022 04:20 AM
Hello bro,
I really thank you for the time you make to reply my post.
I fully understand the MPLS label exchange and data traffic forwarding process. From the answer you got there a part that I was asking about " it strips the label and uses the label to identify the correct VPN routing table." This specific part. I wanted to know how exactly this is done, which table it will look and find the VPN label pointing to the correct VRF.
Check the answer for my question and you will get what I mean. Someone answered.
05-20-2022 05:10 AM
@Harold Ritter answer always superior,
And for myself always learning from his comments.
@Harold Ritter big thanks from me.
05-17-2022 09:26 AM
Hi Friend
your Question make me think and I do LAB and find the answer
CE1-PE1-P-PE2-CE2
in each of PE1 and PE2 there are two entry type in show mpls forwarding-table
1- no label [v] this for the CE connect to each of PE
2- label for LO pf other PE, i.e. PE1 have label for LO of PE2 using for MP-BGP
the trick part there is POP label this confuse me
but when I do lab I find answer
when ping from CE1 to CE2
the PE1 add TWO LABEL
the upper is Label of LO pf PE2
the lower is Label of destination
when traffic reach P the label is POP but which one ??
the Upper one, not lower.
upper one which point to LO of PE2
NOW PE2 receive traffic with only one Label
lower label which check it and fins exactly the VRF for it by checking the IP address add to Label entry.
this how PE2 can forward traffic depend on label.
