Inernet Over MPLS
lakhwaraa
Need help
I have MPLS connection between my main office and branch. I can ping and access my branch from main office and vice versa but can not browse internet. My internet is shared from my main office.
Following is my configuration
Client side
1.
interface GigabitEthernet0 (This is my MPLS interface)
ip address 192.168.20.174 255.255.255.252
ip virtual-reassembly in
zone-member security vpn
duplex auto
speed auto
2. router bgp 64525  (BGP configuration as provided by MPLS Provider)
bgp log-neighbor-changes
network 172.20.48.0 mask 255.255.255.0
neighbor 192.168.20.173 remote-as 38264
ip forward-protocol nd
3. interface Vlan1 (Local Interface)
description $ETH-SW-LAUNCH$$INTF-INFO-FE 1$
ip address 172.20.48.1 255.255.255.0
ip nat inside
zone-member security inside
ip tcp adjust-mss 1452
ip access-list extended NAT
permit ip 172.20.48.0 0.0.0.255 any
7 Replies 7
You must check the show ip route, show ip bgp
the default route must know by your HQ.
balaji.bandi
is this NAT configured on Remote Client side, we do not see NAT Outside, and NAT config here ( we only see ACL ?)
BB
You point is OK but he pass traffic to HQ via MPLS then HQ do NAT,
the NAT must be in HQ to make it route back for Site.
that what I know.
Thanks for the reply
as i already told, my other sites works fine but not this site. (All sites have same configuration)
MPLS is connected to switch which is connected to Router
my HQ is
Giga Switch conf
1. interface Vlan250
ip address 192.168.10.2 255.255.255.252
2.interface Vlan1
ip address 10.30.1.249 255.255.255.0
2. 3. router bgp 85245
network 0.0.0.0
network 10.30.1.0 mask 255.255.255.0 (This is my tunnel running EIGRP)
neighbor 192.168.30.1 remote-as 26438
4. interface GigabitEthernet1/0/23
description $ Mpls Interface $
switchport access vlan 250
switchport mode access
spanning-tree portfast edge
interface GigabitEthernet1/0/1
switchport mode trunk
spanning-tree portfast edge trunk
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
description $ local lan interface $
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
Router
1. interface GigabitEthernet0/1
ip address 19.15.20.121 255.255.255.248 (Direct Internet)
ip mtu 1492
ip nat outside
duplex auto
speed auto
2. interface Vlan1 (Local Lan)
ip address 10.30.1.254 255.255.255.0
ip nat inside
3. ip nat inside source list mynat interface GigabitEthernet0/1 overload
4. ip nat outside source list NAT-OUT-IN pool POOL-OUT-IN
5. ip route 0.0.0.0 0.0.0.0 19.15.20.121
6. ip access-list extended mynat
permit ip 172.30.48.0 0.0 0.0.0.255 any
while on branch side
zone security inside
zone security outside
zone security vpn
1. interface FastEthernet8 (Internet connected)
ip address 192.168.18.2 255.255.255.0
ip nat outside
zone-member security outside
duplex auto
speed auto
2. interface GigabitEthernet0 (MPLS)
ip address 192.168.10.174 255.255.255.252
duplex auto
speed auto
3. interface Vlan1 (Local Lan)
ip address 172.30.48.1 255.255.255.0
ip nat inside
4. router bgp 85245
network 172.30.48.0 mask 255.255.255.0
neighbor 192.168.10.173 remote-as 26438
5. ip access-list extended NAT
permit ip 172.30.48.0 0.0.0.255 any
if other branch  working, you just need to replicating same setup this this branch, you need to compare the config working vs notworking, and only required to change is p2p IP address branch VLAN IP address, have you done that (if not done that way you need to cross check the config).
Can you post one of the working branch config or compare ?
BB
Yes
this is my other branchf configuration and it works fine.
ip nat outside
duplex auto
speed auto
ip address 192.168.10.234 255.255.255.252
duplex auto
speed auto
interface Vlan1
ip address 172.30.31.1 255.255.255.0
ip nat inside
ip tcp adjust-mss 1445
router bgp 85245
network 172.30.31.0 mask 255.255.255.0
neighbor 192.168.10.233 remote-as 26438
permit ip 172.30.31.0 0.0.0.255 any
Firend this site have two defualt route
One direct through internet direct connect and other through mpls bgp,
Staitc router have AD lower than mpls bgp this make site send traffic to internet direct not to HQ.
