How many SVC calls can this X25 interface handle in the interface output?
maryodriscoll
Serial1/2 is up, line protocol is up
Hardware is CD2430 in sync mode
Description: Test
MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec, rely 255/255, load 1/255
Encapsulation X25, loopback not set
X.25 DCE, address <none>, state R1, modulo 8, timer 0
Defaults: idle VC timeout 0
cisco encapsulation
input/output window sizes 2/2, packet sizes 128/128
Timers: T10 60, T11 180, T12 60, T13 60
Channels: Incoming-only none, Two-way 1-1024, Outgoing-only none
RESTARTs 1/0 CALLs 0+8/2580+10/2590+0 DIAGs 0/0
LAPB DCE, state CONNECT, modulo 8, k 7, N1 12056, N2 20
T1 3000, T2 0, interface outage (partial T3) 0, T4 0
VS 0, VR 7, tx NR 7, Remote VR 0, Retransmissions 0
Queues: U/S frames 0, I frames 0, unack. 0, reTx 0
IFRAMEs 12720/12919 RNRs 0/0 REJs 0/0 SABM/Es 1/0 FRMRs 0/0 DISCs 0/0
Last input 00:00:01, output 00:00:01, output hang never
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
38748 packets input, 397658 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
41842 packets output, 314727 bytes, 0 underruns
0 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
Luton#
4095 is the sum of pvcs, incoming svc, two-way svc, outgoing svc. You can split this total as you like better as long the other side is aware of the ranges.
Hop this helps, please rate post if it does!
paolo bevilacqua
X.25 can support up to 4095 VCs. The range must be agreed with the service provider.
Thanks but what about SVC's..the config doesn't seem to indicate any limit on the number of incoming/outgoing SVC calls that can be made so can I assume that I have a mx of 4095. The interface on this router is directly connected to a 3rd party over a leased line with X25 encapsulation on the interface. This is not part of the public X25 network.
interface Serial1/2
description Test
bandwidth 64
no ip address
no ip directed-broadcast
encapsulation x25 dce
no ip mroute-cache
no cdp enable
