how to allow the logs pass from the fortigate to the server
jackhunter
hey help me plz I want to send Syslog logs of my router to the elk server in the internal interface of my FortiGate I294766800_562538495424875_9082956238751245529_n.png configured the Syslog in the router, I configure a policy rule in my FortiGate and I configured filebeat in the elk server but didn't work I don't receive the Syslog logs how can I follow the Syslog logs from my router to see the problem where?
balaji.bandi
On router : you configure as below :
logging enable
logging host  ( Logging or ELK IP)
logging trap level
On fortigate create  FW rule to allow source IP router and destination syslog server IP - protocol udb /514 allow/ accept
BB
for the port, I use 9002 like the doc of elastic I configure the port 9002 in /etc/filebeat/modules.d/cisco.yml and the same in the cisco router but it still not working I try to test with this architecture to see if the problem from FortiGate or no and it doesn't work also the cisco router don't send the logs to elastic
have you changed the port in the cisco router config, post-show run config to look?
are you see any Logs in Fortigate FW  for that traffic?
BB
what does the filebeat module config look like ? Make sure it looks like below:
- module: cisco
ios:
var.syslog_host: 0.0.0.0
var.syslog_port: 9002
