08-15-2022 08:00 AM - edited 08-16-2022 11:12 AM
Hi All,
I'm having below setup in my network. ISRs are is acting as route-reflectors. Huawei F1A is a route reflect client. MikroTik 1 and 2 are normal iBGP peers. Huawei F1A is advertising 2 prefixes to route-reflectors via iBGP. However, these two prefixes are not advertised to MikroTik 1 by both RR1 and RR2. The same prefixes are advertised to MikroTik 2 by both reflectors. Below are my findings and troubleshooting did. I could not think of anything else as same ISRs are advertising the prefixes to other routers without any issue. Appreciate your guys input to find out the root cause. I can share any configuration upon request.
1. 2 iBGP routes exist in RR bgp table.
2. Next-hop is reachable
3. Synchronization is disabled.
4.BGP sessions has been re-established
08-15-2022 08:52 AM
only share the RR config and
show ip bgp in both RR
08-15-2022 08:56 AM
Hello
can you confirm if the RRs are peer to each other?
08-15-2022 09:10 AM
Hi Paul,
Yes they are peer to each other and sharing one cluster id.
08-15-2022 10:47 AM
Hello
@Chanuka D wrote:
Hi Paul,
Now the possible issue using a single cluster-id with dual RR its that a form loop prevention just like as-path
debug bgp ipv4 unicast updates - post the output
08-15-2022 10:58 AM
.Aug 16 01:53:44: BGP(0): 103.78.33.252 rcv UPDATE about 93.189.208.0/21 -- withdrawn
.Aug 16 01:53:44: BGP(0): no valid path for 93.189.208.0/21
.Aug 16 01:53:44: BGP(0): 103.78.33.252 rcv UPDATE about 179.49.248.0/22 -- withdrawn
.Aug 16 01:53:44: BGP(0): no valid path for 179.49.248.0/22
.Aug 16 01:53:44: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 6939 6461 19940, AS_PATH
.Aug 16 01:53:44: BGP(0): 103.78.33.252 rcvd 199.89.147.0/24
.Aug 16 01:53:44: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 93.189.208.0/21
.Aug 16 01:53:44: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 179.49.248.0/22
.Aug 16 01:53:44: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 199.89.147.0/24
.Aug 16 01:53:44: BGP(0): (base) 103.78.35.41 send unreachable (format) 93.189.208.0/21
.Aug 16 01:53:44: BGP(0): (base) 103.78.35.41 send UPDATE (format) 199.89.147.0/24, next 103.78.33.252, metric 0, path 38278 6939 6461 19940
.Aug 16 01:53:44: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 174 1299 6939 6939 136106 141920 141920, AS_PATH
.Aug 16 01:53:44: BGP(0): 103.78.33.252 rcvd 103.165.148.0/24
.Aug 16 01:53:44: BGP(0): 103.78.33.252 rcvd 103.165.149.0/24
.Aug 16 01:53:44: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 6939 136106 149893, AS_PATH
.Aug 16 01:53:44: BGP(0): 103.78.33.252 rcvd 103.190.48.0/23
.Aug 16 01:53:44: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 6939 6762 16735 270888 270888, AS_PATH
.Aug 16 01:53:44: BGP(0): 103.78.33.252 rcvd 177.129.241.0/24
.Aug 16 01:53:44: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 6939 52320 7738 28323 28650, AS_PATH
.Aug 16 01:53:44: BGP(0): 103.78.33.252 rcvd 201.77.0.0/23
.Aug 16 01:53:44: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 174 53013 53135, AS_PATH
.Aug 16 01:53:44: BGP(0): 103.78.33.252 rcvd 177.39.252.0/24
.Aug 16 01:53:44: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 9304 6453 174 174 174 174 399077 399077, AS_PATH
.Aug 16 01:53:44: BGP(0): 103.78.33.252 rcvd 156.240.210.0/24
.Aug 16 01:53:44: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin ?, localpref 100, merged path 38278 174 9304 10118 17794, AS_PATH
.Aug 16 01:53:44: BGP(0): 103.78.33.252 rcvd 202.45.88.0/24
.Aug 16 01:53:44: BGP(0): 103.78.33.252 rcvd 203.145.74.0/24
.Aug 16 01:53:44: BGP(0): 103.78.33.252 rcvd 203.145.78.0/24
.Aug 16 01:53:44: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 6939 45430 133481, AS_PATH
.Aug 16 01:53:44: BGP(0): 103.78.33.252 rcvd 58.136.168.0/22
.Aug 16 01:53:44: BGP(0): 103.78.33.252 rcvd 58.136.172.0/22
.Aug 16 01:53:44: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, atomic-aggregate, aggregated by 31126 100.64.255.2, merged path 38278 6762 174 42020 31126, AS_PATH
.Aug 16 01:53:44: BGP(0): 103.78.33.252 rcvd 89.108.175.0/24
.Aug 16 01:53:44: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 58.136.168.0/22
.Aug 16 01:53:44: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 58.136.172.0/22
.Aug 16 01:53:44: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 89.108.175.0/24
.Aug 16 01:53:44: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 103.165.148.0/24
.Aug 16 01:53:44: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 103.165.149.0/24
.Aug 16 01:53:44: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 103.190.48.0/23
.Aug 16 01:53:44: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 156.240.210.0/24
.Aug 16 01:53:44: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 177.39.252.0/24
.Aug 16 01:53:44: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 177.129.241.0/24
.Aug 16 01:53:44: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 201.77.0.0/23
.Aug 16 01:53:44: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 202.45.88.0/24
.Aug 16 01:53:44: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 203.145.74.0/24
.Aug 16 01:53:44: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 203.145.78.0/24
.Aug 16 01:53:44: BGP(0): (base) 103.78.35.41 send UPDATE (format) 58.136.168.0/22, next 103.78.33.252, metric 0, path 38278 6939 45430 133481
.Aug 16 01:53:44: BGP(0): (base) 103.78.35.41 send UPDATE (format) 89.108.175.0/24, next 103.78.33.252, metric 0, path 38278 6762 174 42020 31126
.Aug 16 01:53:44: BGP(0): (base) 103.78.35.41 send UPDATE (format) 103.165.148.0/24, next 103.78.33.252, metric 0, path 38278 174 1299 6939 6939 136106 141920 141920
.Aug 16 01:53:44: BGP(0): (base) 103.78.35.41 send UPDATE (format) 103.190.48.0/23, next 103.78.33.252, metric 0, path 38278 6939 136106 149893
.Aug 16 01:53:44: BGP(0): (base) 103.78.35.41 send UPDATE (format) 156.240.210.0/24, next 103.78.33.252, metric 0, path 38278 9304 6453 174 174 174 174 399077 399077
.Aug 16 01:53:44: BGP(0): (base) 103.78.35.41 send UPDATE (format) 177.39.252.0/24, next 103.78.33.252, metric 0, path 38278 174 53013 53135
.Aug 16 01:53:44: BGP(0): (base) 103.78.35.41 send UPDATE (format) 177.129.241.0/24, next 103.78.33.252, metric 0, path 38278 6939 6762 16735 270888 270888
.Aug 16 01:53:44: BGP(0): (base) 103.78.35.41 send UPDATE (format) 201.77.0.0/23, next 103.78.33.252, metric 0, path 38278 6939 52320 7738 28323 28650
.Aug 16 01:53:44: BGP(0): (base) 103.78.35.41 send UPDATE (format) 202.45.88.0/24, next 103.78.33.252, metric 0, path 38278 174 9304 10118 17794
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcv UPDATE about 45.234.145.0/24 -- withdrawn
.Aug 16 01:53:46: BGP(0): no valid path for 45.234.145.0/24
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcv UPDATE about 45.235.98.0/23 -- withdrawn
.Aug 16 01:53:46: BGP(0): no valid path for 45.235.98.0/23
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcv UPDATE about 102.135.223.0/24 -- withdrawn
.Aug 16 01:53:46: BGP(0): no valid path for 102.135.223.0/24
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcv UPDATE about 103.137.218.0/24 -- withdrawn
.Aug 16 01:53:46: BGP(0): no valid path for 103.137.218.0/24
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcv UPDATE about 103.139.232.0/24 -- withdrawn
.Aug 16 01:53:46: BGP(0): no valid path for 103.139.232.0/24
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcv UPDATE about 103.169.88.0/24 -- withdrawn
.Aug 16 01:53:46: BGP(0): no valid path for 103.169.88.0/24
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcv UPDATE about 130.137.147.0/24 -- withdrawn
.Aug 16 01:53:46: BGP(0): no valid path for 130.137.147.0/24
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcv UPDATE about 131.100.80.0/22 -- withdrawn
.Aug 16 01:53:46: BGP(0): no valid path for 131.100.80.0/22
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcv UPDATE about 131.100.80.0/23 -- withdrawn
.Aug 16 01:53:46: BGP(0): no valid path for 131.100.80.0/23
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcv UPDATE about 131.100.80.0/24 -- withdrawn
.Aug 16 01:53:46: BGP(0): no valid path for 131.100.80.0/24
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcv UPDATE about 131.100.81.0/24 -- withdrawn
.Aug 16 01:53:46: BGP(0): no valid path for 131.100.81.0/24
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcv UPDATE about 131.100.82.0/24 -- withdrawn
.Aug 16 01:53:46: BGP(0): no valid path for 131.100.82.0/24
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcv UPDATE about 156.240.210.0/24 -- withdrawn
.Aug 16 01:53:46: BGP(0): no valid path for 156.240.210.0/24
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, aggregated by 39010 212.98.131.122, merged path 38278 6939 3356 42020 39010, AS_PATH
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 213.204.80.0/24
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 45.234.145.0/24
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 45.235.98.0/23
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 102.135.223.0/24
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 103.137.218.0/24
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 103.139.232.0/24
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 103.169.88.0/24
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 130.137.147.0/24
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 131.100.80.0/24
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 131.100.80.0/23
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 131.100.80.0/22
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 131.100.81.0/24
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 131.100.82.0/24
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 156.240.210.0/24
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 213.204.80.0/24
.Aug 16 01:53:46: BGP(0): (base) 103.78.35.41 send unreachable (format) 45.234.145.0/24
.Aug 16 01:53:46: BGP(0): (base) 103.78.35.41 send UPDATE (format) 213.204.80.0/24, next 103.78.33.252, metric 0, path 38278 6939 3356 42020 39010
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 6939 6762 16735 264328, AS_PATH
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 138.122.48.0/22
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 6762 12956 10429 263500 263500 263500, AS_PATH
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 177.223.52.0/23
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin ?, localpref 100, merged path 38278 9304 3223 7162, AS_PATH
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 45.181.60.0/24
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 6762 174 174 174 174 399077 399077, AS_PATH
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 154.91.100.0/24
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 6762 12956 10429 263500, AS_PATH
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 177.223.57.0/24
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 45.181.60.0/24
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 138.122.48.0/22
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 154.91.100.0/24
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 177.223.52.0/23
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 177.223.57.0/24
.Aug 16 01:53:46: BGP(0): (base) 103.78.35.41 send UPDATE (format) 45.181.60.0/24, next 103.78.33.252, metric 0, path 38278 9304 3223 7162
.Aug 16 01:53:46: BGP(0): (base) 103.78.35.41 send UPDATE (format) 138.122.48.0/22, next 103.78.33.252, metric 0, path 38278 6939 6762 16735 264328
.Aug 16 01:53:46: BGP(0): (base) 103.78.35.41 send UPDATE (format) 154.91.100.0/24, next 103.78.33.252, metric 0, path 38278 6762 174 174 174 174 399077 399077
.Aug 16 01:53:46: BGP(0): (base) 103.78.35.41 send UPDATE (format) 177.223.52.0/23, next 103.78.33.252, metric 0, path 38278 6762 12956 10429 263500 263500 263500
.Aug 16 01:53:46: BGP(0): (base) 103.78.35.41 send UPDATE (format) 177.223.57.0/24, next 103.78.33.252, metric 0, path 38278 6762 12956 10429 263500
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 6762 3356 13904, AS_PATH
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 64.68.236.0/22
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 6939 3491 17072 28414, AS_PATH
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 200.33.240.0/24
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 200.33.241.0/24
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 200.33.244.0/24
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 6762 14840 263522 263522 263522 263522, AS_PATH
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 131.108.224.0/24
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 131.108.227.0/24
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 177.126.221.0/24
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin ?, localpref 100, merged path 38278 174 9009, AS_PATH
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 85.121.242.0/23
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 85.121.246.0/23
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 146.70.136.0/24
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 198.145.153.0/24
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 198.145.156.0/24
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 198.145.158.0/24
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 6762 14840 263522, AS_PATH
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 131.108.224.0/22
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, atomic-aggregate, merged path 38278 9304 3223 263702 263702 263702 266777 266777 266777 266777, AS_PATH
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 45.235.99.0/24
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 6939 45430 133481, AS_PATH
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 184.22.0.0/22
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 184.22.4.0/22
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 184.22.64.0/22
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 184.22.68.0/22
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 184.22.72.0/22
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 184.22.76.0/22
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 184.22.144.0/22
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 184.22.148.0/22
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 184.22.152.0/22
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 184.22.156.0/22
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 184.22.160.0/22
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 184.22.164.0/22
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 184.22.168.0/22
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 184.22.172.0/22
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 184.22.176.0/22
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 184.22.180.0/22
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 184.22.184.0/22
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 184.22.188.0/22
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 184.82.8.0/22
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 184.82.12.0/22
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 184.82.16.0/22
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 184.82.20.0/22
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 184.82.24.0/22
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 184.82.28.0/22
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 6939 40676, AS_PATH
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 45.35.240.0/23
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 45.35.242.0/23
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 45.35.244.0/22
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 103.59.110.0/23
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 172.106.38.0/23
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 172.106.40.0/21
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 172.106.56.0/22
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 172.106.60.0/22
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 172.106.90.0/23
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 172.106.96.0/21
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 172.106.154.0/23
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 172.106.156.0/22
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 172.106.196.0/22
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 172.106.212.0/22
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 172.106.216.0/22
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 172.106.232.0/22
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 172.107.42.0/23
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 172.107.64.0/20
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 174 4230 61884 264416 266172, AS_PATH
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 160.19.248.0/24
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 160.19.249.0/24
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 160.19.250.0/24
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 160.19.251.0/24
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 45.35.240.0/23
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 45.35.242.0/23
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 45.35.244.0/22
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 45.235.99.0/24
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 64.68.236.0/22
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 85.121.242.0/23
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 85.121.246.0/23
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 103.59.110.0/23
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 131.108.224.0/24
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 131.108.224.0/22
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 131.108.227.0/24
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 146.70.136.0/24
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 160.19.248.0/24
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 160.19.249.0/24
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 160.19.250.0/24
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 160.19.251.0/24
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 172.106.38.0/23
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 172.106.40.0/21
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 172.106.56.0/22
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 172.106.60.0/22
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 172.106.90.0/23
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 172.106.96.0/21
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 172.106.154.0/23
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 172.106.156.0/22
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 172.106.196.0/22
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 172.106.212.0/22
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 172.106.216.0/22
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 172.106.232.0/22
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 172.107.42.0/23
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 172.107.64.0/20
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 177.126.221.0/24
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 184.22.0.0/22
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 184.22.4.0/22
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 184.22.64.0/22
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 184.22.68.0/22
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 184.22.72.0/22
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 184.22.76.0/22
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 184.22.144.0/22
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 184.22.148.0/22
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 184.22.152.0/22
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 184.22.156.0/22
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 184.22.160.0/22
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 184.22.164.0/22
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 184.22.168.0/22
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 184.22.172.0/22
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 184.22.176.0/22
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 184.22.180.0/22
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 184.22.184.0/22
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 184.22.188.0/22
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 184.82.8.0/22
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 184.82.12.0/22
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 184.82.16.0/22
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 184.82.20.0/22
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 184.82.24.0/22
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 184.82.28.0/22
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 198.145.153.0/24
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 198.145.156.0/24
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 198.145.158.0/24
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 200.33.240.0/24
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 200.33.241.0/24
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 200.33.244.0/24
.Aug 16 01:53:46: BGP(0): (base) 103.78.35.41 send UPDATE (format) 45.35.240.0/23, next 103.78.33.252, metric 0, path 38278 6939 40676
.Aug 16 01:53:46: BGP(0): (base) 103.78.35.41 send UPDATE (format) 45.235.99.0/24, next 103.78.33.252, metric 0, path 38278 9304 3223 263702 263702 263702 266777 266777 266777 266777
.Aug 16 01:53:46: BGP(0): (base) 103.78.35.41 send UPDATE (format) 64.68.236.0/22, next 103.78.33.252, metric 0, path 38278 6762 3356 13904
.Aug 16 01:53:46: BGP(0): (base) 103.78.35.41 send UPDATE (format) 85.121.242.0/23, next 103.78.33.252, metric 0, path 38278 174 9009
.Aug 16 01:53:46: BGP(0): (base) 103.78.35.41 send UPDATE (format) 131.108.224.0/24, next 103.78.33.252, metric 0, path 38278 6762 14840 263522 263522 263522 263522
.Aug 16 01:53:46: BGP(0): (base) 103.78.35.41 send UPDATE (format) 131.108.224.0/22, next 103.78.33.252, metric 0, path 38278 6762 14840 263522
.Aug 16 01:53:46: BGP(0): (base) 103.78.35.41 send UPDATE (format) 160.19.248.0/24, next 103.78.33.252, metric 0, path 38278 174 4230 61884 264416 266172
.Aug 16 01:53:46: BGP(0): (base) 103.78.35.41 send UPDATE (format) 184.22.0.0/22, next 103.78.33.252, metric 0, path 38278 6939 45430 133481
.Aug 16 01:53:46: BGP(0): (base) 103.78.35.41 send UPDATE (format) 200.33.240.0/24, next 103.78.33.252, metric 0, path 38278 6939 3491 17072 28414
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 6939 7545, AS_PATH
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 203.19.107.0/24
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 6762 16509, AS_PATH
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 130.137.78.0/24
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, atomic-aggregate, aggregated by 64705 144.104.74.1, merged path 38278 6762 3356 209 721 27064 367 1541, AS_PATH
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 146.16.203.0/24
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 174 9304 10118 17794, AS_PATH
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 202.45.88.0/24
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 203.145.74.0/24
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 203.145.78.0/24
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 174 8612 28937, AS_PATH
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 93.189.208.0/21
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 6762 264409 28650, AS_PATH
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 201.77.0.0/23
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 9304 15412 174 399077 399077, AS_PATH
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 154.91.101.0/24
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, atomic-aggregate, aggregated by 31126 100.64.255.2, merged path 38278 6939 5511 42020 42020 42020 42020 42020 42020 31126, AS_PATH
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 89.108.175.0/24
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, aggregated by 133847 192.168.255.9, merged path 38278 9304 3223 133847, AS_PATH
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 103.43.108.0/24
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 89.108.175.0/24
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 93.189.208.0/21
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 103.43.108.0/24
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 130.137.78.0/24
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 146.16.203.0/24
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 154.91.101.0/24
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 201.77.0.0/23
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 202.45.88.0/24
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 203.19.107.0/24
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 203.145.74.0/24
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 203.145.78.0/24
.Aug 16 01:53:46: BGP(0): (base) 103.78.35.41 send UPDATE (format) 89.108.175.0/24, next 103.78.33.252, metric 0, path 38278 6939 5511 42020 42020 42020 42020 42020 42020 31126
.Aug 16 01:53:46: BGP(0): (base) 103.78.35.41 send UPDATE (format) 93.189.208.0/21, next 103.78.33.252, metric 0, path 38278 174 8612 28937
.Aug 16 01:53:46: BGP(0): (base) 103.78.35.41 send UPDATE (format) 103.43.108.0/24, next 103.78.33.252, metric 0, path 38278 9304 3223 133847
.Aug 16 01:53:46: BGP(0): (base) 103.78.35.41 send UPDATE (format) 130.137.78.0/24, next 103.78.33.252, metric 0, path 38278 6762 16509
.Aug 16 01:53:46: BGP(0): (base) 103.78.35.41 send UPDATE (format) 146.16.203.0/24, next 103.78.33.252, metric 0, path 38278 6762 3356 209 721 27064 367 1541
.Aug 16 01:53:46: BGP(0): (base) 103.78.35.41 send UPDATE (format) 154.91.101.0/24, next 103.78.33.252, metric 0, path 38278 9304 15412 174 399077 399077
.Aug 16 01:53:46: BGP(0): (base) 103.78.35.41 send UPDATE (format) 201.77.0.0/23, next 103.78.33.252, metric 0, path 38278 6762 264409 28650
.Aug 16 01:53:46: BGP(0): (base) 103.78.35.41 send UPDATE (format) 202.45.88.0/24, next 103.78.33.252, metric 0, path 38278 174 9304 10118 17794
.Aug 16 01:53:46: BGP(0): (base) 103.78.35.41 send UPDATE (format) 203.19.107.0/24, next 103.78.33.252, metric 0, path 38278 6939 7545
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 174 1299 16509, AS_PATH
.Aug 16 01:53:46: BGP(0): 103.78.33.252 rcvd 130.137.102.0/24
.Aug 16 01:53:46: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 130.137.102.0/24
.Aug 16 01:53:46: BGP(0): (base) 103.78.35.41 send UPDATE (format) 130.137.102.0/24, next 103.78.33.252, metric 0, path 38278 174 1299 16509
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 6939 7545 7545 7545 7545 7545 7545 7545 7545 7545, AS_PATH
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 203.19.107.0/24
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 203.19.107.0/24
.Aug 16 01:54:23: BGP(0): (base) 103.78.35.41 send UPDATE (format) 203.19.107.0/24, next 103.78.33.252, metric 0, path 38278 6939 7545 7545 7545 7545 7545 7545 7545 7545 7545
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, aggregated by 22006 97.64.66.21, merged path 38278 6939 3356 22006, AS_PATH
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 174.46.12.0/22
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, aggregated by 61424 192.168.121.33, merged path 38278 6939 1299 174 29405 61424, AS_PATH
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 5.35.174.0/24
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 174 14840 263522 263522 263522 263522, AS_PATH
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 131.108.224.0/24
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 131.108.227.0/24
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 177.126.221.0/24
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 6939 22356 262952, AS_PATH
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 170.244.107.0/24
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, atomic-aggregate, aggregated by 65028 10.4.4.4, merged path 38278 6939 3356 209 721 27064 367 306, AS_PATH
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 55.85.0.0/16
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, atomic-aggregate, aggregated by 64753 150.196.226.5, merged path 38278 6939 3356 209 721 27064 367 1541, AS_PATH
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 158.11.10.0/24
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 6939 3356 13904, AS_PATH
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 64.68.236.0/22
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 5.35.174.0/24
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 55.85.0.0/16
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 64.68.236.0/22
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 131.108.224.0/24
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 131.108.227.0/24
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 158.11.10.0/24
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 170.244.107.0/24
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 174.46.12.0/22
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 177.126.221.0/24
.Aug 16 01:54:23: BGP(0): (base) 103.78.35.41 send UPDATE (format) 5.35.174.0/24, next 103.78.33.252, metric 0, path 38278 6939 1299 174 29405 61424
.Aug 16 01:54:23: BGP(0): (base) 103.78.35.41 send UPDATE (format) 55.85.0.0/16, next 103.78.33.252, metric 0, path 38278 6939 3356 209 721 27064 367 306
.Aug 16 01:54:23: BGP(0): (base) 103.78.35.41 send UPDATE (format) 64.68.236.0/22, next 103.78.33.252, metric 0, path 38278 6939 3356 13904
.Aug 16 01:54:23: BGP(0): (base) 103.78.35.41 send UPDATE (format) 131.108.224.0/24, next 103.78.33.252, metric 0, path 38278 174 14840 263522 263522 263522 263522
.Aug 16 01:54:23: BGP(0): (base) 103.78.35.41 send UPDATE (format) 158.11.10.0/24, next 103.78.33.252, metric 0, path 38278 6939 3356 209 721 27064 367 1541
.Aug 16 01:54:23: BGP(0): (base) 103.78.35.41 send UPDATE (format) 170.244.107.0/24, next 103.78.33.252, metric 0, path 38278 6939 22356 262952
.Aug 16 01:54:23: BGP(0): (base) 103.78.35.41 send UPDATE (format) 174.46.12.0/22, next 103.78.33.252, metric 0, path 38278 6939 3356 22006
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 174 3356 139341, AS_PATH
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 43.159.125.0/24
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 6762 7738 262999 262999 262999 262999 262999 263919 263919 263919 263919 263919, AS_PATH
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 170.0.210.0/23
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 6939 52320 61832 263500 263500 263500 263500, AS_PATH
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 177.223.52.0/23
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 177.223.57.0/24
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 6762 16735 264328, AS_PATH
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 138.122.48.0/22
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 6939 7713, AS_PATH
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 36.76.248.0/22
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 36.77.4.0/22
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 36.77.148.0/22
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 36.77.180.0/22
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 61.94.160.0/22
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 110.137.87.0/24
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 125.162.76.0/22
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 125.165.14.0/24
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 180.242.92.0/22
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 132837 7473 6461 1299 271934, AS_PATH
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 38.10.178.0/24
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin ?, localpref 100, merged path 38278 6762 174 17557 9260 135523 137014, AS_PATH
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 103.100.103.0/24
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 6939 3356 42020 39010, AS_PATH
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 213.204.80.0/24
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 36.76.248.0/22
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 36.77.4.0/22
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 36.77.148.0/22
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 36.77.180.0/22
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 38.10.178.0/24
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 43.159.125.0/24
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 61.94.160.0/22
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 103.100.103.0/24
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 110.137.87.0/24
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 125.162.76.0/22
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 125.165.14.0/24
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 138.122.48.0/22
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 170.0.210.0/23
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 177.223.52.0/23
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 177.223.57.0/24
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 180.242.92.0/22
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 213.204.80.0/24
.Aug 16 01:54:23: BGP(0): (base) 103.78.35.41 send UPDATE (format) 36.76.248.0/22, next 103.78.33.252, metric 0, path 38278 6939 7713
.Aug 16 01:54:23: BGP(0): (base) 103.78.35.41 send UPDATE (format) 38.10.178.0/24, next 103.78.33.252, metric 0, path 38278 132837 7473 6461 1299 271934
.Aug 16 01:54:23: BGP(0): (base) 103.78.35.41 send UPDATE (format) 43.159.125.0/24, next 103.78.33.252, metric 0, path 38278 174 3356 139341
.Aug 16 01:54:23: BGP(0): (base) 103.78.35.41 send UPDATE (format) 103.100.103.0/24, next 103.78.33.252, metric 0, path 38278 6762 174 17557 9260 135523 137014
.Aug 16 01:54:23: BGP(0): (base) 103.78.35.41 send UPDATE (format) 138.122.48.0/22, next 103.78.33.252, metric 0, path 38278 6762 16735 264328
.Aug 16 01:54:23: BGP(0): (base) 103.78.35.41 send UPDATE (format) 170.0.210.0/23, next 103.78.33.252, metric 0, path 38278 6762 7738 262999 262999 262999 262999 262999 263919 263919 263919 263919 263919
.Aug 16 01:54:23: BGP(0): (base) 103.78.35.41 send UPDATE (format) 177.223.52.0/23, next 103.78.33.252, metric 0, path 38278 6939 52320 61832 263500 263500 263500 263500
.Aug 16 01:54:23: BGP(0): (base) 103.78.35.41 send UPDATE (format) 213.204.80.0/24, next 103.78.33.252, metric 0, path 38278 6939 3356 42020 39010
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 6939 5511 327708 37020 37020 37020 37020 37020 328928, AS_PATH
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 196.1.137.0/24
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 132837 7713, AS_PATH
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 36.90.28.0/23
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 174 14840 263522, AS_PATH
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 131.108.224.0/22
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 6939 16509 16509, AS_PATH
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 130.137.78.0/24
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 6939 6762 53013 53135, AS_PATH
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 177.39.252.0/24
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 174 3257 34984 44217 206391, AS_PATH
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 185.187.204.0/24
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 174 19429 19429 19429 5722, AS_PATH
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 168.176.205.0/24
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 168.176.213.0/24
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 6939 9009, AS_PATH
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 85.121.242.0/23
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 85.121.246.0/23
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 146.70.136.0/24
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 198.145.153.0/24
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 198.145.156.0/24
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 198.145.158.0/24
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd UPDATE w/ attr: nexthop 103.78.33.252, origin i, localpref 100, merged path 38278 9498 133311 133311 133311 133311 133311 133311 141317 141317 141317 141317 141317, AS_PATH
.Aug 16 01:54:23: BGP(0): 103.78.33.252 rcvd 103.159.152.0/24
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 36.90.28.0/23
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 85.121.242.0/23
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 85.121.246.0/23
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 103.159.152.0/24
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 130.137.78.0/24
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 131.108.224.0/22
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 146.70.136.0/24
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 168.176.205.0/24
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 168.176.213.0/24
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 177.39.252.0/24
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 185.187.204.0/24
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 196.1.137.0/24
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 198.145.153.0/24
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 198.145.156.0/24
.Aug 16 01:54:23: BGP: topo global:IPv4 Unicast:base Remove_fwdroute for 198.145.158.0/24
.Aug 16 01:54:23: BGP(0): (base) 103.78.35.41 send UPDATE (format) 36.90.28.0/23, next 103.78.33.252, metric 0, path 38278 132837 7713
.Aug 16 01:54:23: BGP(0): (base) 103.78.35.41 send UPDATE (format) 85.121.242.0/23, next 103.78.33.252, metric 0, path 38278 6939 9009
.Aug 16 01:54:23: BGP(0): (base) 103.78.35.41 send UPDATE (format) 103.159.152.0/24, next 103.78.33.252, metric 0, path 38278 9498 133311 133311 133311 133311 133311 133311 141317 141317 141317 141317 141317
.Aug 16 01:54:23: BGP(0): (base) 103.78.35.41 send UPDATE (format) 130.137.78.0/24, next 103.78.33.252, metric 0, path 38278 6939 16509 16509
.Aug 16 01:54:23: BGP(0): (base) 103.78.35.41 send UPDATE (format) 131.108.224.0/22, next 103.78.33.252, metric 0, path 38278 174 14840 263522
.Aug 16 01:54:23: BGP(0): (base) 103.78.35.41 send UPDATE (format) 168.176.205.0/24, next 103.78.33.252, metric 0, path 38278 174 19429 19429 19429 5722
.Aug 16 01:54:23: BGP(0): (base) 103.78.35.41 send UPDATE (format) 177.39.252.0/24, next 103.78.33.252, metric 0, path 38278 6939 6762 53013 53135
.Aug 16 01:54:23: BGP(0): (base) 103.78.35.41 send UPDATE (format) 185.187.204.0/24, next 103.78.33.252, metric 0, path 38278 174 3257 34984 44217 206391
.Aug 16 01:54:23: BGP(0): (base) 103.78.35.41 send UPDATE (format) 196.1.137.0/24, next 103.78.33.252, metric 0, path 38278 6939 5511 327708 37020 37020 37020 37020 37020 328928
All possible debugging has been turned off
08-15-2022 11:28 AM
Hello
etc
etc
etc...x 50
The nexthop for these updates is being seen orignating IGP and then to incomplete, Are you redistributing?
08-15-2022 09:49 PM
103.78.33.252 is my loopback of MikroTik 1. It is advertised via IGP not redistributed.
08-16-2022 06:35 AM
Are you peering with the loopback?
08-16-2022 11:03 AM
Yes. all routers use loopback IP for peering.
08-15-2022 11:34 AM
no valid path for 93.189.208.0/21 <<- this meaning that Next-hop is unreachable
but you mention that the next-hop reachable ??
I think that the next-hop is learn via BGP and hence you enter into LOOP.
08-15-2022 09:53 PM
YEs. next-hop is 103.78.33.252, it is reachable from both RR. no packet loss
08-16-2022 01:59 AM
That not correct to check next hope
Select any bgp prefix, use it next hop in ping ftom mikro
The bgp peer is reachable but prefix next hop is not,
That because we deal with ibgp peer which keep next hop unchanged.
08-16-2022 02:52 AM
Hi the issue is not the prefix next-hop. My own prefixes are not advertised to iBGP neighbor by RR.
08-16-2022 05:04 AM
the RR reflection the prefix it receive from RR-client to all other NON client,
here Huawei (RR-client)
the Mikro is NON-Client
RR advertise the prefix BUT before Mikro receive the prefix it valid it...
here the Issue when the RR reflection the prefix it not change the next-hop which is Huawei,
the Mikro must valid the path and the next-hop is Huawei BUT it dont know how reach Huawei so the prefix it refuse by Mikro.
use next-hop-self in RR and issue will be solve
