How to break cisco 1941 router password
arjunsawant
Hi all.....
I have cisco 1941 router.unfortunately i dont remember password.Can any body tell me how to break password.
I tried to go in Rom mon using ctr+break but nothing is happened.
Pls provide any link.....Any help is appreciated....Thanx..
6 Replies 6
Jerry Ye
Ganesh Hariharan
Hi all.....
Check out the below link fro password recovery procedure
http://www.cisco.com/en/US/products/hw/routers/ps259/products_password_recovery09186a0080094675.shtml
http://www.ciscokits.com/password/1.pdf
Hope to Help !!
Ganesh.H
Remember to rate the helpful posthttp://www-tss.cisco.com/eservice/compass/common/activities/Tool-confreg.htm
Below is the cisco link to password recovery procedure for almost all Cisco devices.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_tech_note09186a00801746e6.shtml
sandeepd10
1)Reboot Router
2)press CTRL +Break key
Sent from Cisco Technical Support Android App
http://www.cisco.com/en/US/products/ps5855/products_password_recovery09186a0080b3911d.shtml
Rate the tags which are helpful....
Thanveer
"Everybody is genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is a stupid."
Rohan_Pagar
Try following method with Hyper Terminal :
Complete these steps to simulate a break key sequence:
Connect to the router with these terminal settings:
1200 baud rate
No parity
8 data bits
1 stop bit
No flow control
You no longer see any output on your screen, and this is normal.
Power cycle (switch off and then on) the router and press the SPACEBAR for 10-15 seconds in order to generate a signal similar to the break sequence.
Disconnect your terminal, and reconnect with a 9600 baud rate. You enter the ROM Monitor mode.
<after getting into ROMMON follow below steps>
rommon 1 > confreg 0x2142
rommon 2 > reset
Router#copy startup-config running-config
Router(config)#enable secret < password >
Router#show ip interface brief
<unshut the shutdown interfaces>
Router(config)#config-register 0x2102
Router#copy running-config startup-config
<restart router>
