how to change default Vlan
adriatikb
Could be changed the default Vlan (not native vlan). does exist any command to change it? i want to switch number from vlan 1 to X vlan without manually move all ports.
thanks.
Edison Ortiz
The default vlan will always be Vlan 1 and it can't be changed.
You can change a group of switchports from the default Vlan 1 to Vlan X by using the
interface range
command, for instance:
switch(config)#interface range fx/1-48
switch(config)#switchport access vlan x
HTH,
__
Edison.
Adriatik,
I'm not sure that I understand your question.
Let's say VLAN 10.
What about these command?
(conf)#vlan 10
(conf)#interface range g0/1 - 24
(conf-ran-if)#swi acc vla 10
Toshi
Edison Ortiz
interface range
HTH,
__
Edison.
thanks
