How to change Local BGP id
fortis123
We have a rtr with loopback set to 10.10.10.10/24. The router has EBGP peering with ISP router via serial link. No bgp router-id configured for the rtr.
SHOW IP BGP SUMMARY:
Local BGP identifier as Lo address (10.10.10.10).
I removed the Lo0 and clear the neighbor , still the SHOW IP BGP SUMMARY showing the BGP identifier as :lo0 (which is no longer existing).
Any reason...?
Also, removing the Lo0 will cause any issue to BGP peering..?
Please suggest..
Thank you in advance
MS
7 Replies 7
guruprasadr
Level 7
Level 7
HI MS, [Pls Rate if Helps]
Normally, Prefer the route that comes from the BGP router with the lowest router ID.
The router ID is the highest IP address on the router, with preference given to loopback addresses. Also, you can use the bgp router-id command to manually set the router ID.
Please try: "clear bgp session"
PLS RATE if HELPS
Best Regards,
Guru Prasad R
If your neighbor has peered with you over the loopback address (or if you have used neighbor x.x.x. update-source loopback0), it will affect the peering relationship and the remote end router may be required to reconfigure the peer address
Narayan
wlsj
router-id just like name,an ID,it is chosen from an address but no an address
Thank you for the replies , but the rtr has simple config like this...
interface Loopback0
ip address 10.10.10.10 255.255.255.0
router bgp 3333
bgp log-neighbor-changes
network 10.10.10.0 mask 255.255.255.0
neighbor 23.53.53.17 remote-as 8426
neighbor 23.53.53.17 next-hop-self
neighbor 23.53.53.17 soft-reconfiguration inbound
interface Serial0
ip address 23.53.53.18 255.255.255.252
TEN-1700-R1#sh ip bgp sum
BGP router identifier 10.10.10.10 , local AS number 3333
--> Even after removing Lo0 i/f and clearing the BGP session....
Any clues..? Do I need to reboot the rtr..??
Thanks in advance
MS
The BGP route ID is choosen when BGP (the process) is started or when a new ID is configured. Then it is kept, even if the loopback from which the ID was choosen is deleted. If you clear a neighbor, it will terminate the TCP session to that neighbor, but will not terminate the BGP process locally on the router.
To change the BGP ID use
router BGP 3333
bgp router-id A.B.C.D
After that you might have to clear BGP.
Hope this helps! Please rate all posts.
Regards, Martin
MS,
I tried to replicate your issue and though the router ID was the same even after removing the loopback interface, it changed after I cleared the BGP process.
R1#sh ip bgp s
BGP router identifier 10.10.10.10, local AS number 3333
BGP table version is 3, main routing table version 3
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
23.53.53.17 4 8426 4 6 3 0 0 00:01:27 0
R1#sh ip bgp s
23.53.53.17 4 8426 4 6 3 0 0 00:01:28 0
R1#clear ip bgp *
R1#
*Mar 1 00:08:18.799: %BGP-5-ADJCHANGE: neighbor 23.53.53.17 Down User reset
R1#
R1#
R1#
R1#sh ip bgp s
*Mar 1 00:08:20.323: %BGP-5-ADJCHANGE: neighbor 23.53.53.17 Up
R1#sh ip bgp s
BGP router identifier 23.53.53.18, local AS number 3333
BGP table version is 1, main routing table version 1
23.53.53.17 4 8426 8 11 1 0 0 00:00:02 0
R1#
R1#sh run | b r b
router bgp 3333
no synchronization
no auto-summary
interface Serial1/0
What IOS are you running?
-Vaibhav
Hi all,
Thank you for the replies and tests.
The IOS : Version 12.1(6) rtr:1700
Thank you
MS
