How to check Bandwidth Utilization
one of P2P link  bandwidth was fully utilizing.. I need to check the Bandwidth utilization Application wise is it Possible on router or any other tool required to the same, if so could u explain about the tool.
7 Replies 7
Leo Laohoo
What is the bandwidth of the WAN link?
Post the output to the command "sh interface ".
The Bandwith of link is 25 Mbps. I am checking through Sh int summary. utilization showing 25 Mbps.
Post it.  There's something I'm looking for.
SWTCORP01#sh interfaces gigabitEthernet 1/43 summary
*: interface is up
  IHQ: pkts in input hold queue     IQD: pkts dropped from input queue
  OHQ: pkts in output hold queue    OQD: pkts dropped from output queue
  RXBS: rx rate (bits/sec)          RXPS: rx rate (pkts/sec)
  TXBS: tx rate (bits/sec)          TXPS: tx rate (pkts/sec)
  TRTL: throttle count
  Interface               IHQ   IQD  OHQ   OQD  RXBS RXPS  TXBS TXPS TRTL
* GigabitEthernet1/43      0     0    0     0 27643000  2281 533000  1039
But My question is how to check the traffic application wise?
Application?  You want to check which application is chewing the bandwidth?
It will depend if your router or firewall or wireless LAN controller will support Application Visibility and Control (AVC).
Try Command "#sh controllers vdsl 0"
It will show you useful router stats including speed, power and noise on the line.
not working in ISR4321
