How to clear virtual-access interfaces
mario.jost
Level 3
Level 3
We have a FlexVPN Setup where Spoke2Spoke connections get created dynamically with the help of virtual access interfaces. So if i want to edit something within a virtual-template, i get the error that it is locked:
router(config)#interface Virtual-Template2
% Virtual-template config is locked, active vaccess present
If i then show all the interfaces, i can see that there are still virtual-access interfaces that got clonec from this virtual-template 2:
router#show ip interface brief | include Access
Virtual-Access1 172.18.0.132 YES unset up down
Virtual-Access2 172.18.0.132 YES unset up down
Virtual-Access3 172.18.0.132 YES unset up down
Virtual-Access4 172.18.0.132 YES unset up down
Virtual-Access5 172.18.0.132 YES unset up down
Virtual-Access6 172.18.0.132 YES unset up down
Virtual-Access7 172.18.0.132 YES unset up down
Virtual-Access8 172.18.0.132 YES unset up down
Virtual-Access9 172.18.0.132 YES unset up down
Virtual-Access10 172.19.0.76 YES unset up down <--- These wer cloned from VT2
Virtual-Access11 172.19.0.76 YES unset up down <--- These wer cloned from VT2
Virtual-Access12 172.18.0.132 YES unset up down
Virtual-Access13 172.18.0.132 YES unset up down
Virtual-Access15 172.18.0.132 YES unset up down
Virtual-Access16 172.19.0.76 YES unset up down <--- These wer cloned from VT2
So we can see that these interfaces are up down. There are no active VPN connections anymore to the destinations that these virtual-access interfaces were brought up. So i just go ahead and shut the tunnel2 interface, which gives me following picture:
Virtual-Access10       unassigned      YES unset  up                    down    <- unassigned IP
Virtual-Access11       unassigned      YES unset  up                    down    <- unassigned IP
Virtual-Access16       unassigned      YES unset  up                    down    <- unassigned IP
So if i try to run the command clear interface virtual-access10 this does nothing:
router#clear interface virtual-access 10
router#clear interface virtual-access 11
router#show ip int brief | include Access
Virtual-Access10       unassigned      YES unset  up                    down    <- still here
Virtual-Access11       unassigned      YES unset  up                    down    <- still here
There are no NHRP entries active (as there are no Spoke2Spoke VPNs active) So my go-to workaround has always been to just shut the tunnel2 and reload the router. Shutting the tunnel2 makes sure no new virtual-access connections will be created after the router is back online. But with this, i have to wait for a maintenance window and its a pretty bad workaround to be honest. Is there another way to remove these virtual-access interfaces in order to edit the virtual template interface?
First, there are svti tunnel toward hub
And there is virtual template between spokes
Config new virtual template with different number, then add it under the ikev2 profile
Lastly shut the old virtual template and remove it
MHM
balaji.bandi
You can create a new virtual template assign to profile if you like to change, or shutdown the tunnel and make changes.
BB
