how to compare performance after tune OSPF network
Maivoko
besides fast convergence time and least number of topology change
which command and in which content can compare performance after tune OSPF network
which OSPF parameters have you changed, and what does your topology look like ? Below is a list of all the OSPF debug commands:
Router#debug ip ospf ?
adj OSPF adjacency events
database-timer OSPF database timer
events OSPF events
flood OSPF flooding
hello OSPF hello events
lsa-generation OSPF lsa generation
mpls OSPF MPLS
nsf OSPF non-stop forwarding events
packet OSPF packets
retransmission OSPF retransmission events
spf OSPF spf
tree OSPF database tree
24 Replies 24
 Try to transfer  files using iPerf.  Would be better if you had transfered something before for comparison.
If in packettracer or gns3,
how to compare ?
GNS3 you can integrate with VMs. Packetracert is more limited.
events OSPF events
flood OSPF flooding
mpls OSPF MPLS
packet OSPF packets
spf OSPF spf
Ispf level 1 and timer throttle spf and hello timer
is there more parameters that can improve ospf?
moreover, I see timer throttle spf use topology change time just more than it little
where can find this change time?
i know spanning tree topology change
but where is ospf topology change time for timer throttle spf?
Cisco has a info on tuning both OSPF or EIGRP. See if you can find in on their main site.
If there is one path from one area and another area and near no topology change
can we adjust hello timer to maximum time?
Yea, you could, but the whole point it to catch the loss ASAP. Otherwise you might black hole traffic for the duration of the hello timer timeout.
What do it mean to catch the loss?
how to find this loss?
why do no topology change have loss?
For "catch the loss" I have in mind the loss of a link.  However it could also be the addition of link, but adding links often doesn't have the impact to traffic that losing a link does.
Finding the link loss (or addition) would be by monitoring the route table and/or OSPF database.
A topology change would cause a loss (or addition), but neither might not impact traffic.
How to simulate this loss or reproduce this loss situation?
Manually remove or add a network to the topology.
If there is no addition or remove link in bank network
where is the smallest number of topology change come from?
If there is no change to topology, you shouldn't be receiving topology changes.
