how to compare performance after tune OSPF network
Maivoko
besides fast convergence time and least number of topology change
which command and in which content can compare performance after tune OSPF network
24 Replies 24
Joseph W. Doherty
Transfer performance, within your network shouldn't change when you "tune" OSPF.
As you note, what you should see (in some cases) is faster convergence.
I cannot recall any tools designed to measure that.
You could try something like stopping advertising a network on one end of the network and measuring how fast the other end of the network receives the change. Likewise flapping a route (i.e. its addition and withdrawal) and measure the difference in impact.
Will flapping event terminate the connection of tcp?
how flapping event influence tcp connection and udp connection?
Flapping might break connections if the route is lost for an extended amount of time.
How to reduce number of flapping event to zero permanently and ensure never have flapping event?
"ensure never", unsure anyone knows the answer to that.
Technologies like "dampening", though can mitigate the impact.
What cause flapping event?
can network device return to no flapping event occur itself?
what should do when flapping event occur?
Often cause by a poor connection where routing hellos are lost. Might also be caused by congestion is routing hellos are dropped.
Don't understand your second question.
What to do? Identify cause and mitigate.
If in real practice hello lost only happen one time , how do you know the cause come from hello lost or congestion?
any command show?
i mean if real practice it happen flap
but in debug or testing it did not happen,
how to identify the cause?
You often ignore a single event.
However, if there's a flap, you trace to the cause.
As to what commands to use and/or how to identify, you might start by readining Cisco's troubleshooting notes on their main site.
rasmus.elmholt
Level 7
Level 7
I would configure NTP, configure the logging timestamp msec service, and then debug ip routing when you do the tests.
Regards.
