How to configure 857w to a dumb ADSL2+ modem?
rocknolds
Can someone please show me how to configure a cisco 857w adsl router to function as a dumb adsl2+ modem only?
I have been trying to do this at home following few of those what I've found after searching forums in google and I am not successful.
Many thanks
7 Replies 7
paolo bevilacqua
You need first to know VPI/VCI values.
hello p.bevilacqua
its 8/35
Hi...
You need to upgrade your IOS to advance service and then in Dialer 0, it has to be dsl operating mode adsl2+ or dsl operating mode auto
Tabrez
Can someone just show me a config please?
Below is the current configurations:
SHOW VERSION
Cisco857w#show version
Cisco IOS Software, C850 Software (C850-ADVSECURITYK9-M), Version 12.4(11)T2,
LEASE SOFTWARE (fc4)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Tue 01-May-07 08:56 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE
Cisco857w uptime is 16 weeks, 4 days, 9 hours, 55 minutes
System image file is "flash:c850-advsecurityk9-mz.124-11.T2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 857W (MPC8272) processor (revision 0x300) with 59392K/6144K bytes of mem
y.
Processor board ID FHK125125T9
MPC8272 CPU Rev: Part Number 0xC, Mask Number 0x10
4 FastEthernet interfaces
1 ATM interface
1 802.11 Radio
128K bytes of non-volatile configuration memory.
20480K bytes of processor board System flash (Intel Strataflash)
SHOW RUNNING-CONFIG
Cisco857w#show run
Building configuration...
Current configuration : 6038 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service sequence-numbers
hostname Cisco857w
boot-start-marker
boot-end-marker
logging buffered 16000
no logging console
enable secret 5 $1$MlGU$kfvuUUGSI6EO8ohAcTkt1.
no aaa new-model
no ip source-route
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp pool CUSTOMER_LAN_POOL
   network 10.10.10.0 255.255.255.0
   default-router 10.10.10.1
   dns-server A.B.C.D X.Y.Z.W
ip cef
no ip bootp server
ip domain name direct.telstra.net
ip name-server A.B.C.D
ip name-server X.Y.Z.W
ip ssh version 2
crypto pki trustpoint TP-self-signed-3974344100
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3974344100
revocation-check none
rsakeypair TP-self-signed-3974344100
crypto pki certificate chain TP-self-signed-3974344100
certificate self-signed 01
  3082025C 308201C5 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33393734 33343431 3030301E 170D3032 30333031 30303037
  32345A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 39373433
  34343130 3030819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100A90E D7505FE0 4CFBDA7C E9CCF763 DCEB5F39 33491CC8 6A76A2D1 97390DE3
  688F549A 05BF017A 7DB89D77 39CB06D2 914AD696 A5789AD4 2DC51F44 75F3D59B
  15F982A6 55DDEFEB 5485BFD1 B618270E CC59B360 4783C06E 319C2E89 E8535DD4
  B483F905 8DE4E3AB 16FA5239 90D527D3 A5FA51CD D1DBFE14 409B9512 388143B4
  B5970203 010001A3 81833081 80300F06 03551D13 0101FF04 05300301 01FF302D
  0603551D 11042630 24822254 425F4242 5F416476 616E7461 67652E64 69726563
  742E7465 6C737472 612E6E65 74301F06 03551D23 04183016 8014C907 2C24D981
  D5A7E5F9 CD485C38 921C8719 E836301D 0603551D 0E041604 14C9072C 24D981D5
  A7E5F9CD 485C3892 1C8719E8 36300D06 092A8648 86F70D01 01040500 03818100
  6C1B9027 EB330206 F954A340 5CCA0157 7F6AD0B5 9F8BEEB9 D02585C7 BD5981B9
  96850F56 1336AF92 A53267FC C449F99E 18CE6712 BA376AC4 0D9179A5 5EB6E50F
  FF864B3F 39F3F116 3DB8472C 9C08EDA1 B5F14834 BBDE3644 BFEBEB51 763DE552
  70F8995E A947923C 7A48410B 803CA3A5 4692BCA2 CBDACCFA 893D337A 3048FCF3
  quit
username UserName privilege 15 secret 5 $1$WTVe$AxGuNNZhkwNRUYanptSkF/
interface ATM0
no ip address
no ip route-cache cef
no ip route-cache
load-interval 30
no atm ilmi-keepalive
pvc 8/35
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
dsl operating-mode auto
interface FastEthernet0
spanning-tree portfast
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0        54.0
station-role root
interface Vlan1
description CUSTOMER_LOCAL_LAN
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip virtual-reassembly
interface Dialer0
description ADSL Link FNN xxxxxxx
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
encapsulation ppp
ip route-cache flow
dialer pool 1
no cdp enable
ppp authentication chap callin
ppp chap hostname UserName@ISP
ppp chap password 7 15465F54577E7C
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http access-class 22
ip http authentication local
ip http secure-server
ip nat source static esp 10.10.10.2 interface Dialer0
ip nat source static udp 10.10.10.2 500 interface Dialer0 500
ip nat source static udp 10.10.10.2 5500 interface Dialer0 5500
ip nat source static udp 10.10.10.2 1701 interface Dialer0 1701
ip nat source static udp 10.10.10.2 4500 interface Dialer0 4500
ip nat source static tcp 10.10.10.2 51 interface Dialer0 51
ip nat source static tcp 10.10.10.2 10000 interface Dialer0 10000
ip nat source static udp 10.10.10.2 10000 interface Dialer0 10000
ip nat source static udp 10.10.10.2 10001 interface Dialer0 10001
ip nat source static tcp 10.10.10.2 10001 interface Dialer0 10001
ip nat inside source list 22 interface Dialer0 overload
ip nat inside source static tcp 10.10.10.2 1723 interface Dialer0 1723
access-list 22 permit 10.10.10.0 0.0.0.255
no cdp run
control-plane
banner login ^C
* Access to this computer system is limited to authorised users only. *
* Unauthorised users may be subject to prosecution under the Crimes   *
*                       Act or State legislation                      *
* Please note, ALL CUSTOMER DETAILS are confidential and must         *
*                         not be disclosed.                           *
^C
line con 0
no modem enable
transport output all
line aux 0
line vty 0 2
exec-timeout 20 0
password 7 045A0F100E2F584F0E1C
login
transport input telnet
line vty 3 4
exec-timeout 20 0
login
transport input ssh
scheduler max-task-time 5000
end
Many thanks guys!!!
Hello Rock,
you need also to understand the type of encapsulation to be implemented:
when you say you would like to configure the router to behave like a dumb DSL modem do you mean like a bridge?
in this case, the modem should take ethernet frames and should put them inside an AAL5 ATM PDU to send over the DSL link.
That is:
IPV4/Ethernet/AAL5/ATM/DSL
This is called RFC1483 bridging mode because the original ip packet is bridged and not routed.
You can find an example of this configuration here:
https://www.cisco.com/en/US/products/hw/routers/ps380/products_configuration_example09186a0080093e50.shtml
But there are other possible encapsulations /service models for DSL services:
Classic IP over ATM: unlikely for home use
in this case the protocol stack is:
IPV4/AAL5/ATM/DSL
here the IPv4 packet is routed this is called RFC 1483 routed.
other very comon services are (they introduce authentication and allows the provider to account for non flat services)
PPP over ATM
PPPoE over ATM.
To be noted that an RFC 1483 bridging supports PPPoE if it it is the PC to run PPPoE client, because PPPoE frames are ethernet frames.
So it  is wise to consult your provider to find out what type of service you have. Configuration will follow.
Hope to help
Giuseppe
Hi...
interface ATM0
no ip address
no ip route-cache
load-interval 30
pvc 8/35
dsl operating-mode adsl2+
It has to be on interface ATM0 and not on dialer0, kindly ensure your ISP has changed your line to support this feature or it is recommended to keep on auto.
thank you guys for the quick replies.
ill get back to you once I get how
