hi there,
y have a lttle problem to cofigure a ADSL2+ Conexion in an 1941 router.
line protocol are up but didn't have ip adresse in my interface...
Current configuration : 1986 bytes
! Last configuration change at 22:32:07 UTC Fri Jan 25 2013
version 15.1
service password-encryption
hostname XXXXXXXXXXXX
boot-start-marker
boot-end-marker
enable password 7 063656356B49394B4F
no aaa new-model
no ipv6 cef
ip source-route
ip cef
vpdn enable
vpdn-group pppoe
request-dialin
protocol l2tp
controller VDSL 0/1/0
operating mode adsl2+
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 192.168.9.250 255.255.255.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 192.168.1.253 255.255.255.0
duplex auto
speed auto
interface ATM0/1/0
no ip address
no atm ilmi-keepalive
pvc 8/81
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Ethernet0/1/0
no ip address
shutdown
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication chap pap callin
ppp chap hostname uribej
ppp chap password 7 055A545C75191849
ppp pap sent-username uribej password 7 11584B5643475D4C
router rip
version 2
network 192.168.1.0
network 192.168.9.0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
access-list 1 permit 192.168.9.0 0.0.0.255
access-list 1 remark "Access liste por el NAT (Internet)"
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password 7 107E500D2210225946
login
transport input all
scheduler allocate 20000 1000
end
show ip interface brief
Embedded-Service-Engine0/0 unassigned YES NVRAM administratively down down
GigabitEthernet0/0 192.168.9.250 YES NVRAM up up
GigabitEthernet0/1 192.168.1.253 YES NVRAM down down
ATM0/1/0 unassigned YES unset down down
Ethernet0/1/0 unassigned YES unset administratively down down
Dialer1 unassigned YES manual up up
NVI0 192.168.9.250 YES unset up up
Virtual-Access1 unassigned YES unset up up
Virtual-Access2 unassigned YES unset down down
i don't know how i can find the probleme, and debug's comandes no show me anything.
I'im located in mexico, and use TELMEX provider.
the conexion is an ADSL2+, and prvider's box conect them with PPPoE...
sorry for my bad english.
thank's for your help,
Start with "show controllers vdsl".
Hello and thank you for your response,
Apparently the line is detected by the controller…
Before comment, I try to put the card in "automatic"
And apparently this line doesn’t work in ADSL2+...
Router#show controllers vdsL 0/1/0
Controller VDSL 0/1/0 is UP
Daemon Status: Up
XTU-R (DS) XTU-C (US)
Chip Vendor ID: 'BDCM' 'ALCB'
Chip Vendor Specific: 0x0000 0x0000
Chip Vendor Country: 0xB500 0xB500
Modem Vendor ID: 'CSCO' ' '
Modem Vendor Specific: 0x4602 0x0000
Modem Vendor Country: 0xB500 0x0000
Serial Number Near: FOC16454FN7 1941/K9 15.1(4)M
Serial Number Far:
Modem Version Near: 15.1(4)M
Modem Version Far: 0x0000
Modem Status: TC Sync (Showtime!)
DSL Config Mode: AUTO
Trained Mode: G.992.1 (ADSL) Annex A
TC Mode: ATM
Selftest Result: 0x00
DELT configuration: disabled
DELT state: not running
Trellis: ON ON
Line Attenuation: 19.0 dB 14.0 dB
Signal Attenuation: 19.0 dB 0.0 dB
Noise Margin: 30.7 dB 28.0 dB
Attainable Rate: 10064 kbits/s 1156 kbits/s
Actual Power: 17.1 dBm 11.9 dBm
Total FECS: 0 0
Total ES: 0 0
Total SES: 0 0
Total LOSS: 0 0
Total UAS: 0 0
Total LPRS: 0 0
Total LOFS: 0 0
Total LOLS: 0 0
Bit swap: 0 0
Full inits: 1
Failed full inits: 0
Short inits: 0
Failed short inits: 0
Firmware Source File Name (version)
VDSL embedded VDSL_LINUX_DEV_01212008 (1)
Modem FW Version: 110506_1916-4.02L.03.A2pv6C032b.d23i
Modem PHY Version: A2pv6C032b.d23i
DS Channel1 DS Channel0 US Channel1 US Channel0
Speed (kbps): 0 2048 0 384
Previous Speed: 0 0 0 0
Total Cells: 0 4602427 0 0
User Cells: 0 0 0 0
Reed-Solomon EC: 0 0 0 0
CRC Errors: 0 0 0 0
Header Errors: 0 0 0 0
Interleave (ms): 0.00 0.25 0.00 0.25
Actual INP: 0.00 0.00 0.00 0.00
Training Log : Stopped
Training Log Filename : flash:vdsllog.bin
Hello!!
Did you tryed with this resolve?
