07-13-2010 10:00 PM - edited 03-04-2019 09:03 AM
I have a quiestion about design of EIGPR.
Here is the topology.
[Router_A]
interface Serial0/0
bandwidth 64
ip address 172.19.0.2 255.255.0.0
no fair-queue
interface Serial0/1
bandwidth 64
ip address 172.16.0.1 255.255.0.0
clock rate 64000
router eigrp 1
network 172.16.0.0
network 172.19.0.0
auto-summary
[Router_B]
interface Serial0/0
ip address 172.16.0.2 255.255.0.0
no fair-queue
interface Serial0/1
bandwidth 64
ip address 172.17.0.1 255.255.0.0
clock rate 64000
router eigrp 1
network 172.16.0.0
network 172.17.0.0
auto-summary
[Router_C]
interface Serial0/0
ip address 172.17.0.2 255.255.0.0
interface Serial0/1
bandwidth 64
ip address 172.18.0.1 255.255.0.0
clock rate 64000
router eigrp 1
network 172.17.0.0
network 172.18.0.0
auto-summary
[Router_D]
interface Serial0/0
ip address 172.18.0.2 255.255.0.0
no fair-queue
interface FastEthernet0/1
ip address dhcp
duplex auto
speed auto
interface Serial0/1
bandwidth 64
ip address 172.19.0.1 255.255.0.0
clock rate 64000
router eigrp 1
network 172.18.0.0
network 172.19.0.0
no auto-summary
And, here is the behavior.
Router_A#show ip route
Gateway of last resort is not set
D 172.17.0.0/16 [90/41024000] via 172.16.0.2, 1d17h, Serial0/1
C 172.16.0.0/16 is directly connected, Serial0/1
C 172.19.0.0/16 is directly connected, Serial0/0
D 172.18.0.0/16 [90/41024000] via 172.19.0.1, 1d17h, Serial0/0
Router_D#show ip route
D 172.17.0.0/16 [90/2681856] via 172.18.0.1, 1d17h, Serial0/0
D 172.16.0.0/16 [90/3193856] via 172.18.0.1, 1d17h, Serial0/0
C 172.19.0.0/16 is directly connected, Serial0/1
C 172.18.0.0/16 is directly connected, Serial0/0
I tried following command to Router_A's S0/1 from Router_D.
Then Router_D selected farther route.
Router_D#traceroute 172.16.0.1
Tracing the route to 172.16.0.1
1 172.18.0.1 12 msec 12 msec 12 msec
2 172.17.0.1 28 msec 28 msec 28 msec
3 172.16.0.1 24 msec 24 msec *
How can I configure so that Router_D can select shortest route.
Okumura
Solved! Go to Solution.
07-13-2010 10:29 PM
make all your interface consistent in bandwidth value. the metric should prefer the shortest path. i do not remember the bandwidth value if you leave serial interface to default.
i see that only router D has no auto-summary. Not sure if it does anything in this case.
07-14-2010 01:14 AM
As you know metric in EIGRB depend on BW, Delay...
First us command no auto-summary for all Routers (has noting to do for calulate pest path)
Second use commanded show ip eigrp topology you will see only feasible successors
and use show ip eigrp topology all-links or show ip eigrp topology summary
for show all update and why EIGRP choose the path
if you don’t understand output you can copy it here to discuss it
07-14-2010 02:33 AM
07-13-2010 10:29 PM
07-14-2010 01:14 AM
07-14-2010 02:22 AM
Hi, chinkevi and Khaled Al Homaidhi.
Thank you so much for your nice advise.
I improved my configuration as you said about bandwidth and this question has resolved.
Here is the result.
[Before improvement]
Router_D#show ip eigrp topology all-links
IP-EIGRP Topology Table for AS(1)/ID(172.18.0.2)
Codes: P - Passive, A - Active, U - Update, Q - Query, R - Reply,
r - reply Status, s - sia Status
P 172.16.0.0/16, 1 successors, FD is 3193856, serno 49
via 172.18.0.1 (3193856/2681856), Serial0/0, serno 31
via 172.19.0.2 (41024000/40512000), Serial0/1
P 172.17.0.0/16, 1 successors, FD is 2681856, serno 48
via 172.18.0.1 (2681856/2169856), Serial0/0
via 172.19.0.2 (41536000/41024000), Serial0/1
P 172.18.0.0/16, 1 successors, FD is 2169856, serno 47
via Connected, Serial0/0
P 172.19.0.0/16, 1 successors, FD is 40512000, serno 12
via Connected, Serial0/1
[After improvement]
P 172.16.0.0/16, 1 successors, FD is 41024000, serno 55
via 172.18.0.1 (41536000/41024000), Serial0/0, serno 56
P 172.17.0.0/16, 1 successors, FD is 41024000, serno 58
via 172.18.0.1 (41024000/40512000), Serial0/0
P 172.18.0.0/16, 1 successors, FD is 40512000, serno 51
D 172.17.0.0/16 [90/41024000] via 172.18.0.1, 00:04:40, Serial0/0
D 172.16.0.0/16 [90/41024000] via 172.19.0.2, 00:04:40, Serial0/1
And show the configuration below.
Router_A#show run | b int
interface Serial0/0
bandwidth 64
no fair-queue
interface Serial0/1
bandwidth 64
clock rate 64000
router eigrp 1
network 172.16.0.0
network 172.19.0.0
no auto-summary
Router_B#show run | b int
interface Serial0/0
bandwidth 64
no fair-queue
interface Serial0/1
bandwidth 64
clock rate 64000
router eigrp 1
network 172.16.0.0
network 172.17.0.0
no auto-summary
Router_C#show run | b int
interface Serial0/0
bandwidth 64
interface Serial0/1
bandwidth 64
clock rate 64000
router eigrp 1
network 172.17.0.0
network 172.18.0.0
no auto-summary
Router_D#show run | b int
interface Serial0/0
bandwidth 64
no fair-queue
interface Serial0/1
bandwidth 64
clock rate 64000
router eigrp 1
network 172.18.0.0
network 172.19.0.0
no auto-summary
Thank you.
Okumura
07-14-2010 02:33 AM
Good luck
That’s it
