How to configure IP SLA for failover in Cisco 1841?
deepthirajt
Should I configure a IP SLA responder?
If yes, How can I do that?
28 Replies 28
Hi Georg,
Thanks for support.
there is nothing configured on that interface on your backup router:
interface GigabitEthernet0/0/1
no ip address
shutdown
negotiation auto
What do you want to configure there ?
Hi Georg,
Thanks...
Hi George,
Thanks.
Hi George,
We are planning to configure IPSec on both router same interface g0/0/1 after configuring IP SLA so some changes require in given IP SLA script.
Please Help...
Hi George,
I have configured IP SLA but while configuration timeout 500 & frequency 3 not accepting it's showing below error.
#Error: timeout is less tean threshold 5000
#Error: frequency is less than timeout 5000
so I have configur 5000 in both command. Kindly help to understand above error & let me know any changes require.
timeout 5000
frequency 5000
I guess I forgot a zero. The values 5000/5000 are fine. Is the SLA working otherwise ?
Hi George,
Thanks...
you are tracking two routes. Post the full configs of both routers. In the meantime, try to just use default routes:
ip route 0.0.0.0 0.0.0.0 10.221.203.13 track 1
ip route 0.0.0.0 0.0.0.0 10.221.1.38 10
Hi Georg,
We have numbers of route which is pointing to deffrent gatway or interface.
If I add a default route so it will effect existing route communication?
Post the full configs of your routers.
If you only have these two networks going out via 10.221.203.17, you can use a default route. Is there anything else going out via 10.221.203.17 ?
ip route 10.221.99.0 255.255.255.0 10.221.203.17 track 1
ip route 10.221.100.0 255.255.255.0 10.221.203.17 track 1
Yes we have numbers of route.
Please check earlier post, I have uploaded both router configuration file.
Post your current full configs...
