How to connect Vlans to Outside Webserver
John Rener
Hello Gurus,
I'm building a lab and trying to connect my vlans to my outside webserver with no success. I must be missing an important config. My routing is all over the place, any help/suggestions/corrections is very much appreciated.
The Test PC which is non vlan can access the web server.
Attached is the packet tracer file.
Thank you in advance!
balaji.bandi
You need to give more information, how is your setup what device connected in the network path from user to internet.
In general setup in basic high level:
Lan (users) --Switch-- Internet router--- Internet ( where the WWW resides).
For the users to connect to Outside Web Server (since you have local users do not have public IP iam guessing, you can not reach to webServer, you need to do NAT with Public IP)
As best practice :
Lan (users) --Switch-- Internet router(nat configuration here in this device)--- Internet ( where the WWW resides).
You need to Look the routing
Natting
Sorry some how iam not able to open the file.
Make sense ?
BB
5 Replies 5
balaji.bandi
As best practice :
Natting
Make sense ?
BB
Which one were you not able to open, the zip or the pkt? I will paste my config.
John Rener
L3 Switch
interface GigabitEthernet0/1
switchport trunk native vlan 100
switchport mode trunk
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan5
mac-address 00e0.8f19.ad01
interface Vlan10
mac-address 00e0.8f19.ad02
ip address 192.168.2.1 255.255.255.0
ip default-gateway 10.10.100.1
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.100.1
Router 2
interface GigabitEthernet0/0/0
ip address 10.10.100.1 255.255.255.252
duplex auto
speed auto
interface GigabitEthernet0/0/1
ip address 192.168.5.1 255.255.255.0
duplex auto
speed auto
interface Serial0/1/0
ip address 10.10.0.1 255.255.255.252
interface Serial0/1/1
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
router eigrp 1
network 192.168.1.0
network 192.168.2.0
network 10.0.0.0
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/1/0
Router 3
no ip address
duplex auto
speed auto
shutdown
ip address 10.10.10.1 255.255.255.0
ip nat inside
duplex auto
speed auto
ip address 10.10.0.2 255.255.255.252
ip nat outside
clock rate 2000000
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
router eigrp 1
network 10.0.0.0
ip nat inside source static 10.10.10.2 10.10.0.2
ip classless
My Test PC is already working. That's a non vlan traffic though.
John Rener
It works now.
The issue was I forgot to setup my routing protocol on L3 switch and ACL and NAT on Router 2.
Good to know...cheers !
BB
