Bookmark
Subscribe
1096
ASR 1002-HX Port Licencing
Hello Everyone!
I have a question here,
Do I need to restart the router after a license activation???
Can´t find any information on the Hardware-Installation document
Thanks!
Sorry, my bad.
To activate the port licenses, all you have to do is unshut 'no shut' the interface the license is for...
yes, you typically need to reload the router after activating the license.
When you do a:
show license
it should give you a line similar to the one below:
Next reload license Level: ipservices
So in this example, ipservices will run after the reload.
Thank you Georg,
But even if it's just for a 2x1GB port license??,
I aggree with you when you upgrade from ipbase to ipservices or advservices, but from ports also?
Sorry, my bad.
Great,
Thank you very much!!
