how to create a tftp server using a pc
tontonkab
need help to solvr problems on router cisco 1700
jarvar832004
u will have to download a software called 3cdaemon and load the image into ur pc. Then u can make ur pc act as the tftp server by giving its ip in the router that needs to download the image
First download a TFTP server program such as Solarwinds TFTP Server --> http://support.solarwinds.net/updates/New-customerFree.cfm?ProdId=52
Then run it on the PC you want to act as TFTP server.
Thereupon you give the IP of this PC as the IP for TFTP server in your devices.
AbhisheK
Please rate helpful posts!!!
