Showing results forĀ
Search instead forĀ
Did you mean:Ā
How to determine if EIGRP is currently configured for this network?
MicJameson1
Hello.
ASA5525# sh eigrp topology
P 172.16.22.0 255.255.255.0, 1 successors, FD is 5376
via Rstatic (5376/0)
via 172.16.222.2 (3072/2816), Inside
via 172.16.222.3 (3072/2816), Inside
As can be seen above, currently there exists 2 static routes for 172.16.22.0. IF EIGRP was configured, I would think the EIGRP route would show here.
QUESTIONS:
1. How can I determine if EIGRP is currently configured for network 172.16.22.0?
2. If I remove theses static routes, will this Anyconnect subnet need return routing? How should this be configured?
Thank you.
The command
show ip protocols
will show you if any routing protocol is configured along with the networks they are configured for. Since they are in the Topology table I would assume that they are static but also part of the EIGRP routing as well.
From your output the static network is
redistributed
into EIGRP. Hence the Rstatic flag. Again the
show ip protocols
will also tell you this.
-David
6 Replies 6
 Please, run this commands
show run | sƩc router
show ip route eigrp
show ip route 172.16.22.0
The command
show ip protocols
redistributed
show ip protocols
-David
MicJameson1
This is an ASA.
Thank you.
show route eigrp
This command exist in asa
This is a local static route (according to the topology table). It trumps EIGRP and will not show up in the show route EIGRP. Unless the ASA output is different than a router in that regard. Or is this not correct? The only way to tell if a local network is configure for EIGRP on the local device is to check the EIGRP process.
I missed that detail. You can check the running config but my statement about the Rstatic is still correct. Once you bring it into the protocol it ends up in the topology table. That's also why the metric is (5376/0).
Also you will not see that route under EIGRP (on that device since its a local/static route) in the routing table.
