How to enable SSH nad nating at the same time
hassan.saleh
Dears,
The problem is i have a static ip on router interface and it is configured for pating.
But i can't ssh to the public ip address unless i remove the IP nat outside on the wan interface.
Is there a solution to this issue?
paolo bevilacqua
Please check the ACL used in "ip nat inside source" command. If it contains "any", that is the cause.
