How to find Cisco 3945 Environment thresholds?
dastrix80
Hi Guys,
Hi Guys how can I find these? Specifically CPU & Power Supply temp thresholds?
Kris
chrihussey
I don't think you'll be able to get the thresholds on a component basis, but instead the operating conditions for the entire unit. I'd assume it would be safe to say that the components would need to fall within these parameters.
https://www.cisco.com/c/en/us/products/collateral/routers/3900-series-integrated-services-routers-isr/data_sheet_c78_553924.html
Hope this helps
