Bookmark
Subscribe
913
How to install G0/0/02 port on 4311 switch
bi13hy
Hi All,
My assignment requires me to attach two routers one using a copper cross-over cabling.
I'm connecting  router 2901 via int g0/0 to router 4311 via inter g0/0/2. However this port is not readily available?
Any suggestions on how to install this port on 4311 router?
Do you have access to the router?
show ip int br
I assume this is a Packet Tracer project, and you are talking about the the 4331/4321 routers ?
You need to do this:
Go to the 'Physical' tab, then select the GLC-T and insert it in the upper or lower right slot (there are 4 slots on the left where you can insert them.
This will enable the interface (see screenshot).
Hello
Can you elaborate on what you mean?
Kind Regards
Paul
Hi Paul,
I've managed to solve the issue.
Through adding additional hardware, NIM 2T and NIM ES2-4.
regards
