How to make a commoun VLAN ??
reagentom
Dear All;
I have Cisco Catalyst Switch 4006 with Supervisor II OS with 4232-L3 routing module, witch is configured for 5 VLANS, each VLAN cann't communicate with others.
I want to make VLAN 5 as a common VLAN so it can communicate with all others VLANS.
Attached is a copy of my show running-config on the routing blade
Please Help
17 Replies 17
is the gigabit subinfterface for vlan 5 is up then?
which port is your laptop attached to?
please give us the copy of show vlan in the switching module, and show interface gigabitEthernet3.5
because last time the 'line protocol' of gigabitethernet3.5 is still down, line protocol status indicate that there is 'something' wrong with layer 2.
this could be the vlan assignments in switching module, or the configuration between switching module and the routing module.
rgrds
Dear Handoko,
attached is required show vlans
hai,
just searching my old doc's
and find this useful links
http://www.cisco.com/en/US/partner/products/hw/switches/ps663/products_configuration_example09186a0080157f51.shtml
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/inst_nts/78_10164.htm
http://www.cisco.com/en/US/partner/products/hw/switches/ps663/products_tech_note09186a0080094959.shtml
i allready see the file "show vlan.txt", status of vlan 5 in switching module is active,
but i don't know whether the status of interface gigabitethernet3.5 is up or down
let's cek those 3 links first, maybe we missed some step.
rgds,
handoko
