How to manage routing & NAT for "secondary" ip address subnet
martinlebel
Hi !
The datacenter I'm hosted at delivered me two subnets of public IP address on the same interface on my CISCO2911 router. The secondary subnet is mainly going to be used for NAT static translations. I'm struggling to get things to work with the secondary subnet. I guess I can't figure out how to tell the router "If traffic comes from subnet A, use default route A and if it comes from subnet B, use default route B"
Routing
Here's what I got so far :
interface GigabitEthernet0/1
ip address 24.24.24.210 255.255.255.248 secondary
ip address 68.68.68.50 255.255.255.240
ip nat outside
--Internal network
interface GigabitEthernet0/2.1
 encapsulation dot1Q 1 native
 ip address 10.99.99.1 255.255.255.0
 ip nat inside
 ip virtual-reassembly in
ip nat inside source route-map RMAP_NAT interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 68.68.68.49
route-map RMAP_NAT permit 100
 match ip address ACL_NAT
ip access-list extended ACL_NAT
permit ip 10.99.99.0 0.0.0.255 any
Thank you
-M
16 Replies 16
Deepak Kumar
Make a configuration like:
ip nat pool wan 24.24.24.210 24.24.24.210 netmask 255.255.255.248
ip nat inside source route-map RMAP_NAT pool wan overload
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hi ! Thanks for helping. I just don't see how 24.24.24.210 255.255.255.248 which is secondary will reach it's default gateway (24.24.24.209) if there's no route to it.
Hello
Your dc is aware of the secondary subnet so it will advertise and route for it - as for traffic being forwarded out of your network then traffic will always use the primary ip address however using static may will work for the primary or secondary addressing
Kind Regards
Paul
Deepak Kumar,
Just to add to Paul's answer.
If the DC has given you a default gateway of 24.24.24.209 with the second subnet that suggests they are using secondary IPs.
Just ask them to route the entire subnet to 68.68.68.50, remove the secondary IP address (.210) from your router's interface and then as Paul says, just create static NATs and it will all work.
Make sure proxy arp is enabled on the router interface.
Jon
Here, Enable the Proxy ARP and no need route for a secondary subnet.
Deepak Kumar,
Hello
@martinlebel wrote:
Hi !
The datacenter I'm hosted at delivered me two subnets of public IP address on the same interface on my CISCO2911 router. The secondary subnet is mainly going to be used for NAT static translations. --
Nothing you need to do, just add the static nat statements as/when you need to
Kind Regards
Paul
Deepak Kumar
Deleted as PBR is not a suitable option.
Deepak Kumar,
Hello
@Deepak Kumar wrote:
PBR will resolve your issue as:
access-list 100 permit ip 1 10.99.99.0 0.0.0.255 any
R1(config)#route-map Secondary_ISP
R1(config-route-map)#match ip address 100
R1(config-route-map)#set ip next-hop 24.24.24.209
R1(config)#interface GigabitEthernet0/2.1
R1(config-subif)#ip policy route-map Secondary_ISP
and keep you all other configuration and add PBR as mentioned above. It will work for you.
This then will push all the lan traffic pertaining to that subnet via the secondary address even more so you will then have the same problem using the primary subnet as you would with the secondary.
My understanding  1-1 static network translation on the secondary addressing would be fine without any need to policy or re-route anything.
Kind Regards
Paul
I am not sure that I am doing right or wrong but I did the same in my lab and here is the result:nat 2.png
R1 Configuration: (Where we need Secondary IP address (CE))
interface FastEthernet0/0
ip nat inside
duplex half
interface FastEthernet1/0
ip address 1.1.1.1 255.255.255.0
ip proxy-arp
ip nat outside
duplex auto
speed auto
ip nat pool wan 2.2.2.1 2.2.2.1 netmask 255.255.255.0
ip nat inside source list 100 pool wan overload
ip nat inside source static 192.168.1.12 1.1.1.1 extendable
ip nat inside source static 192.168.1.2 2.2.2.1 extendable
ip route 0.0.0.0 0.0.0.0 1.1.1.2
access-list 100 permit ip any any
R2 Configuration As ISP Router (PE):
ip address 192.168.10.1 255.255.255.0
duplex half
ip address 2.2.2.2 255.255.255.0 secondary
ip address 1.1.1.2 255.255.255.0
ip proxy-arp
duplex auto
speed auto
Here is the debug output:
(Ping From PC1 to R2 interface F0/0 IP)
R2#debug ip icmp
ICMP packet debugging is on
R2#
*Oct 16 13:00:13.015: ICMP: echo reply sent, src 192.168.10.1, dst 2.2.2.1, topology BASE, dscp 0 topoid 0
R2#
*Oct 16 13:00:14.051: ICMP: echo reply sent, src 192.168.10.1, dst 2.2.2.1, topology BASE, dscp 0 topoid 0
R2#
*Oct 16 13:00:15.091: ICMP: echo reply sent, src 192.168.10.1, dst 2.2.2.1, topology BASE, dscp 0 topoid 0
R2#
*Oct 16 13:00:16.119: ICMP: echo reply sent, src 192.168.10.1, dst 2.2.2.1, topology BASE, dscp 0 topoid 0
R2#
*Oct 16 13:00:17.139: ICMP: echo reply sent, src 192.168.10.1, dst 2.2.2.1, topology BASE, dscp 0 topoid 0
R2#
(PC2 to PC1(2.2.2.1) ping using Static NAT)
Oct 16 13:14:52.287: NAT*: s=192.168.10.2, d=2.2.2.1->192.168.1.2 [6102]
R1(config)#
*Oct 16 13:14:54.291: NAT*: s=192.168.10.2, d=2.2.2.1->192.168.1.2 [6103]
R1(config)#
*Oct 16 13:14:55.307: NAT*: s=192.168.1.2->2.2.2.1, d=192.168.10.2 [6102]
*Oct 16 13:14:55.307: NAT*: s=192.168.1.2->2.2.2.1, d=192.168.10.2 [6103]
*Oct 16 13:14:56.295: NAT*: s=192.168.10.2, d=2.2.2.1->192.168.1.2 [6104]
*Oct 16 13:14:56.303: NAT*: s=192.168.1.2->2.2.2.1, d=192.168.10.2 [6104]
R1(config)#
*Oct 16 13:14:57.311: NAT*: s=192.168.10.2, d=2.2.2.1->192.168.1.2 [6105]
*Oct 16 13:14:57.335: NAT*: s=192.168.1.2->2.2.2.1, d=192.168.10.2 [6105]
R1(config)#
*Oct 16 13:14:58.343: NAT*: s=192.168.10.2, d=2.2.2.1->192.168.1.2 [6106]
*Oct 16 13:14:58.367: NAT*: s=192.168.1.2->2.2.2.1, d=192.168.10.2 [6106]
R1(config)#
(PC2 to (1.1.1.1) PC3 ping using Static NAT)
*Oct 16 13:58:44.387: NAT*: s=192.168.10.2, d=1.1.1.1->192.168.1.12 [8734]
*Oct 16 13:58:44.431: NAT*: s=192.168.1.12->1.1.1.1, d=192.168.10.2 [8734]
R1(config)#
*Oct 16 13:58:45.467: NAT*: s=192.168.10.2, d=1.1.1.1->192.168.1.12 [8735]
*Oct 16 13:58:45.483: NAT*: s=192.168.1.12->1.1.1.1, d=192.168.10.2 [8735]
R1(config)#
*Oct 16 13:58:46.503: NAT*: s=192.168.10.2, d=1.1.1.1->192.168.1.12 [8736]
*Oct 16 13:58:46.519: NAT*: s=192.168.1.12->1.1.1.1, d=192.168.10.2 [8736]
R1(config)#
*Oct 16 13:58:47.511: NAT*: s=192.168.10.2, d=1.1.1.1->192.168.1.12 [8737]
*Oct 16 13:58:47.543: NAT*: s=192.168.1.12->1.1.1.1, d=192.168.10.2 [8737]
R1(config)#
*Oct 16 13:58:48.567: NAT*: s=192.168.10.2, d=1.1.1.1->192.168.1.12 [8738]
*Oct 16 13:58:48.571: NAT*: s=192.168.1.12->1.1.1.1, d=192.168.10.2 [8738]
Deepak Kumar,
@Deepak Kumar
In your lab you have the secondary addressing on the isp (PE) rtr interface towards the client (CE) rtr, This is incorrect the secondary addressing should be applied on the clients (CE) rtr wan facing interface!
Kind Regards
Paul
Hi @paul driver
If you look it closely, it is my gateway IP address for Secondary subnet and it does not require if I will add a static route.
As:
R2(config)#interface fastEthernet 1/0
R2(config-if)#no ip address 2.2.2.2 255.255.255.0 secondary
R2(config)#ip route 2.2.2.0 255.255.255.0 1.1.1.1
R2#sho ip route
Gateway of last resort is not set
1.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 1.1.1.0/24 is directly connected, FastEthernet1/0
L 1.1.1.2/32 is directly connected, FastEthernet1/0
2.0.0.0/24 is subnetted, 1 subnets
S 2.2.2.0 [1/0] via 1.1.1.1
192.168.10.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.10.0/24 is directly connected, FastEthernet0/0
L 192.168.10.1/32 is directly connected, FastEthernet0/0
R2#
(Ping from PC2 to PC1 (2.2.2.1)
PC-2> ping 2.2.2.1
84 bytes from 2.2.2.1 icmp_seq=1 ttl=62 time=122.753 ms
84 bytes from 2.2.2.1 icmp_seq=2 ttl=62 time=36.135 ms
84 bytes from 2.2.2.1 icmp_seq=3 ttl=62 time=31.625 ms
84 bytes from 2.2.2.1 icmp_seq=4 ttl=62 time=25.459 ms
84 bytes from 2.2.2.1 icmp_seq=5 ttl=62 time=36.348 ms
Router1 logs:
R1(config)#
*Oct 16 14:15:03.587: NAT*: s=192.168.10.2, d=2.2.2.1->192.168.1.2 [15036]
*Oct 16 14:15:03.647: NAT*: s=192.168.1.2->2.2.2.1, d=192.168.10.2 [15036]
R1(config)#
*Oct 16 14:15:04.707: NAT*: s=192.168.10.2, d=2.2.2.1->192.168.1.2 [15037]
*Oct 16 14:15:04.719: NAT*: s=192.168.1.2->2.2.2.1, d=192.168.10.2 [15037]
R1(config)#
*Oct 16 14:15:05.751: NAT*: s=192.168.10.2, d=2.2.2.1->192.168.1.2 [15038]
*Oct 16 14:15:05.755: NAT*: s=192.168.1.2->2.2.2.1, d=192.168.10.2 [15038]
R1(config)#
*Oct 16 14:15:06.771: NAT*: s=192.168.10.2, d=2.2.2.1->192.168.1.2 [15039]
*Oct 16 14:15:06.779: NAT*: s=192.168.1.2->2.2.2.1, d=192.168.10.2 [15039]
R1(config)#
*Oct 16 14:15:07.799: NAT*: s=192.168.10.2, d=2.2.2.1->192.168.1.2 [15040]
*Oct 16 14:15:07.815: NAT*: s=192.168.1.2->2.2.2.1, d=192.168.10.2 [15040]
R1(config)#
R1(config)#
Deepak Kumar,
Sam Smiley
Level 3
Level 3
I've never been a fan of using secondary addresses on interfaces; it makes it complicated if you need to source traffic on the LAN that needs to go out through an IP other than the IP assigned to the outside interface. As Paul noted as long as your provider is routing both subnets to your outside interface it is just a matter of assigning the addresses to the outside interface to answer inbound or outbound request. You WAN IP and IP address assigned to your outside interface are fine. You will need to create NAT pools for each of your public addresses as Deepak notes but you don't need to do route maps.
When you you create the NAT pool for the public IP address that will bind the address to the outside Interface. You can then do port translations as you need to for that address. As long as your ISP is routing the subnet to you the router will answer for the address. I have a more detailed answer at the below link that will further clarify what you are trying to do:
https://community.cisco.com/t5/routing/multiple-wan-ip-addresses-and-multiple-inside-hosts/td-p/2181351
Sam
on a side note, if you want to use the secondary addresses just for static NAT, you could use a route map on the static NAT entry that specified the next hop as being the IP address of the other end, 24.24.24.209 in your case. Since static NAT takes precedence, your static entries would always go to the secondary IP.
That would look like this:
access-list 101 permit ip host 10.99.99.101 any
access-list 102 permit ip host 10.99.99.102 any
ip nat inside source static 10.99.99.101 24.24.24.210 route-map STATIC_1
ip nat inside source static 10.99.99.102 24.24.24.211 route-map STATIC_2
ip nat inside source list 1 interface GigabitEthernet0/1 overload
route-map STATIC_1 permit 10
match ip address 101
route-map STATIC_2 permit 10
match ip address 102
