Kill hung process on IOS XE
Roman Pomazanov
Hi all
Is there any possibility to reload or kill process in Cisco IOS-XE software?
One of process have very high CPU and looks "hung".
nspasov
Have you tried:
show processes >>> This will list all of the running processes and will help you locate the PID of the process that you want to kill
clear socket PID
I hope this helps!
Thank you for rating helpful posts!
Hi, Neno
Thanks for your reply.
But unfortunately there is no such possibility to use clear command
#clear socket 404
% Invalid input detected at '^' marker.
I use 03.03.03SE installed on Catalyst 3850
Yes I received this error:
#clear socket 77
There are no open sockets for this process
first try sh sockets and then do clear socket PID that u want to kill from sh socket output.
#clear socket 77
