How to migrate from Cat65-SUP720/2T(mls netflow) to Cat95(Flexible Netflow)
mhiyoshi
Level 3
Level 3
Hello all,
Now I am looking for migration tool from Cat65 to Cat95 Netflow.
Because the configuration of mls netflow on Cat65 is totally different from Flexible Netflow right?
So I would like to let me know if there is any command compare list on both
Here is the related URL but it is not equivalent to this at the moment.
https://www.cisco.com/c/en/us/td/docs/routers/7600/ios/15S/configuration/guide/7600_15_0s_book/nde.pdf
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/16-5/configuration_guide/nmgmt/b_165_nmgmt_9300_cg/b_165_nmgmt_9300_cg_chapter_01000.html
Best Regards,
Masanobu Hiyoshi
balaji.bandi
How about below reference guide (hope this what you looking for ?)
https://www.cisco.com/c/dam/en/us/td/docs/security/stealthwatch/netflow/Cisco_NetFlow_Configuration.pdf
BB
Hi balaj,
That would be great! however would you mind if you let me know Cat65 MLS netflow to Flexible Neflow document? This docs looks well on the point of each product however there does not exist feature difference between them.
Best Regards,
Masanobu Hiyoshi
I do not have in hand to offer that document,
here is fome reference document from cisco i can guide, that helps you build one. - Netflow main for collection of data, so this is not like config migration, it has more advanced feature to collect more data for analysis.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/fnetflow/configuration/xe-16/fnf-xe-16-book/fnf-fnetflow.html
BB
