05-07-2024 01:34 AM
Hi all,
we have a ISP infrastructure, where che customer is authenticated via PPPoE on a leased line, for example, a VDSL line.
The customer have a PPPoE with a private IP address on the PPPoE Client.
The virtual-template have a loopback with a Public IP Address, this ip address is the next-hop for a PPPoE tunnel.
We want to NAT the private IP address on a PPPoE client to the public IP address of a Loopback or public interface of BNG router.
We try with ip nat inside on loopback1 and ip nat outside on the public interface of BNG with a access-list that match only the private IP address of the PPPoE Client, but nothing appened.
Can suggest any solution?
Many thanks.
Solved! Go to Solution.
05-09-2024 12:46 AM
Thank you for the answer, but we have decided to change the device to other vendor, many thanks.
05-07-2024 02:10 PM
can you share the config you use
MHM
05-09-2024 12:46 AM
