Router update issue 4431
sigcerder
Good afternoon everyone.
I need help, I'm trying to update my ISR4431/K9 router and I'm failing.
The original firmware version installed on this router is: isr4400-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin, which is a very old version.
My task is to upgrade to isr4400-universalk9.17.09.04a.SPA.bin.
The first time I try to install this firmware, the system goes into an endless attempt to load it.
Current ROMMON version: 16.12(2r)
What I was able to do, I was able to install 2 firmwares:
1. isr4400-universalk9.17.02.01r.SPA.bin
2. isr4400-universalk9.17.03.08a.SPA.bin
3. The next step was to try to load isr4400-universalk9.17.09.04a.SPA.bin and this is what came out:
show platform
Chassis type: ISR4431/K9
Slot Type State Insert time (ago)
0 ISR4431/K9 ok 02:08:14
0/0 ISR4431-X-4x1GE ok 02:06:47
R0 ISR4431/K9 ok, active 02:08:14
F0 ISR4431/K9 ok, active 02:08:14
P0 Unknown fail, badinput 02:07:44
P1 PWR-4430-AC ok 02:07:44
P2 ACS-4430-FANASSY ok 02:07:44
Slot CPLD Version Firmware Version
0 19042950 16.12(2r)
R0 19042950 16.12(2r)
F0 19042950 16.12(2r)
Spoiler
boot system flash bootflash:isr4400-universalk9.17.09.04a.SPA.bin
reload
Initializing Hardware ...
Checking for PCIe device presence...done
System integrity status: 0x610
Rom image verified correctly
System Bootstrap, Version 16.12(2r), RELEASE SOFTWARE
Copyright (c) 1994-2019 by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: LocalSoft
ISR4431/K9 platform with 2097152 Kbytes of main memory
Located isr4400-universalk9.17.09.04a.SPA.bin
Package header rev 3 structure detected
IsoSize = 738131968
Calculating SHA-1 hash...Validate package: SHA-1 hash:
calculated EF69987D:19928A45:AA4E263B:C3FA1BAE:F06E2A59
expected EF69987D:19928A45:AA4E263B:C3FA1BAE:F06E2A59
RSA Signed RELEASE Image Signature Verification Successful.
Image validated
IsoSize = 738131968
Image validated
Mark Elsen
  - Sometimes you may need to upgrade ROMMON first , check Release Notes of the version you want to install and look for ROMMON ,
 M.
I have tried this before, for this model of router I see the only version of ROMMON available:
isr4400_rommon_1612_2r_SPA.pkg
I installed it and then tried to install the firmware itself, that didn't help either.
