How to only use USB and RAM on a Cisco device
P8834
I have a fairly unusual question. I have a C1111X-8P router that I need to run directly from an USBdevice. So I can disable the internal flash.
So when I power off the unit and remove the USBdevice no traces of the configuration, IOS, VLAN, logs etc. is left in the router. Is this even possible?
I want to disable all permanent storage internally in the device.
5 Replies 5
balaji.bandi
Not that i am ware, instead you can Lock the device, if the stolen or hacked.
suggest to do hardening :
https://www.cisco.com/c/en/us/support/docs/ip/access-lists/13608-21.html
BB
Leo Laohoo
What is the use case for this unusual requirement?
When a router is installed properly, it is very difficult to remove.  If the config, for instance, resides in a USB stick it can easily get swiped without anyone knowing.
It is for a system that is mobile, and when you bring it with you on a plane I want to be able to have the USB with me in person and not with the luggage going through different scans and people on the airport. If it's not possible I have to bring the whole router with the carrie-on luggage.
So it would be really nice if it's possible to do what I described above.
investigate if it is possible (and workable) to configure the router to
- load IOS from tftp-server (boot variable)
- after |IOS is loaded,  copy config from tftp to running-config
on your laptop run tftp a server for this,  do not save config to flash do not install IOS to flash
Very unusual case but it can be done.
Post the complete output to the command "sh boot".
