How to pass internal traffic through the WAN without NAT
MikeAW2010
I am designing a lab topology within EVE-NG that mimic's a prod environment.. ..of course, in the real world, the prod environment uplinks are managed by BGP uplinks. My uplinks however to the WAN must be handled by my local home router. Because of this, My BGP peering ends at the Spine Routers where I advertised the default route 0.0.0.0/0 down stream, and I can confirm my Leaf switches are receiving the advertised 0.0.0.0/0 route through BGP, however; they cannot ping out to the WAN while the spine switches can.. ..I was assuming because I need to NAT-POOL the aggregation of addresses to the interfaces carrying my local private IP (192.168.0.X) to my PHYSICAL router.. ..However; I'm finding these switches do not support NAT and I must use these switches.. ..Is there another way I can provide WAN access to my leaf switches?
9 Replies 9
keep in mind that we have no idea what the configurations of your routers and switches look like, all we see is a picture of a fairly large network. Post the full running configurations of all devices involved in your issue, and indicate what connectivity you want to establish.
Jon Marshall
It's not clear from your description what the issue is.
If the WAN is the internet via your home router and the IPs are private IPs something has to NAT them but not clear why your router can't do that ?
As Georg says all we can see is a picture of a large network where half the devices aren't connected to anything and there is very little IP addressing so it's difficult to give any guidance.
Jon
balaji.bandi
if this is eve-ng, then add one more IOL router to topology do the NAT there.
example :
NET(hope this has internet access)---IOL---- 4 spine connection.
BB
MikeAW2010
Hello. I will confess that these are DellOS10 switches and unfortunately I confirmed they do not support NATTING, while the CLI is largely based on Cisco, the OS is entirely different. I was thinking of putting a Cisco router in the topology just before my physical router (the cloud) and connecting the Spine switches to it with a public IP between the Spines and the Cisco's, but I'm unsure if that will work...
Basically I am currently only worried about Spine1_G1, Spine2_G1, sw1001a and sw1001b
In short, Both Spine1 and Spine2 are able to connect to my home router and ping the WAN (8.8.8.8)
sw1001a and sw1001b are receiving the default route 0.0.0.0/0 through BGP into their routing table but those cannot ping 8.8.8.8 -- I was assuming that my Spine switches will need some sort of NATTING in this scenario:
Configs posted and also attached as attachments:
sw1001a
sw1001a# show running-configuration
! Version 10.5.2.3
! Last configuration change at Feb  03 23:37:47 2022
ip vrf default
system-user linuxadmin password ****
iscsi target port 860
iscsi target port 3260
hostname sw1001a
username admin password **** role sysadmin priv-lvl 15
aaa authentication login default local
aaa authentication login console local
class-map type application class-iscsi
policy-map type application policy-iscsi
virtual-network 10101
virtual-network 10201
virtual-network 10301
virtual-network 10401
virtual-network 10501
virtual-network 10601
virtual-network 11000
virtual-network 11001
virtual-network 13939
port-group 1/1/1
 mode Eth 25g-4x
port-group 1/1/2
 mode Eth 25g-4x
port-group 1/1/3
 mode Eth 25g-4x
port-group 1/1/4
 mode Eth 25g-4x
port-group 1/1/5
 mode Eth 25g-4x
port-group 1/1/6
 mode Eth 25g-4x
port-group 1/1/7
 mode Eth 25g-4x
port-group 1/1/8
 mode Eth 25g-4x
port-group 1/1/9
 mode Eth 25g-4x
port-group 1/1/10
 mode Eth 25g-4x
port-group 1/1/11
 mode Eth 25g-4x
port-group 1/1/12
 mode Eth 25g-4x
port-group 1/1/13
 mode Eth 100g-2x
port-group 1/1/14
 mode Eth 100g-2x
port-group 1/1/15
 mode Eth 100g-1x
port-group 1/1/16
 mode Eth 100g-1x
port-group 1/1/17
 mode Eth 100g-1x
port-group 1/1/18
 mode Eth 100g-1x
interface vlan1
 no shutdown
 ip address dhcp vendor-class ZTD
interface vlan101
 description Management_Vlan
 no shutdown
 mtu 9128
interface vlan201
 description VSAN_Vlan
 no shutdown
 mtu 9128
interface vlan301
 description vMotion_Vlan
 no shutdown
 mtu 9128
interface vlan401
 description NSX_T_Virtual_Edge_Tep
 no shutdown
 mtu 9128
interface vlan501
 description Host_TEP_Vlan
 no shutdown
 mtu 9128
interface vlan601
 description Edge_TEP_Vlan
 no shutdown
 mtu 9128
interface vlan901
 description VCF_BGP_Peering
 no shutdown
 mtu 9216
 ip address 10.60.100.129/27
 ipv6 address xxxx:xxx:xxxx:d0:2::1/80
interface vlan1000
 description "NSX-T Virtual edge peering local VLAN"
 no shutdown
 mtu 9216
interface vlan1001
 no shutdown
 mtu 9128
interface vlan3939
 description VxRail_Discovery_Vlan
 no shutdown
interface vlan4000
 description "VLT Peer L3 Underlay Path"
 no shutdown
 mtu 9128
 ip address 10.60.96.128/31
 ipv6 address xxxx:xxx:xxxx:d0:1::128/127
interface port-channel17
 description Connected_to_Spine_s5g1_13.1
 no shutdown
 no switchport
 mtu 9178
 ip address 10.210.10.97/31
 ipv6 address xxxx:xxx:xxx:b46::a61/127
interface port-channel18
 description Connected_to_Spine_s13g1_14.1
 no shutdown
 no switchport
 mtu 9178
 ip address 10.210.14.97/31
 ipv6 address xxxx:xxx:xxx:b46::e61/127
interface port-channel19
 description Connected_to_Spine_s5g2_13.1
 no shutdown
 no switchport
 mtu 9178
 ip address 10.210.18.97/31
 ipv6 address xxxx:xxx:xxx:b46::1261/127
interface port-channel20
 description Connected_to_Spine_s13g2_29.1
 no shutdown
 no switchport
 mtu 9178
 ip address 10.210.22.97/31
 ipv6 address xxxx:xxx:xxx:b46::1661/127
interface loopback0
 description Loopback
 no shutdown
 mtu 9178
 ip address 96.109.93.151/32
 ipv6 address xxxx:xxx:xxx::2:0:197/128
interface loopback1
 description HARDWARE_VXLAN
 no shutdown
 ip address 10.60.96.1/32
nve
 source-interface loopback1
interface mgmt1/1/1
 no shutdown
 ipv6 address autoconfig
interface ethernet1/1/1
 description VLTi-link1
 no shutdown
 no switchport
 flowcontrol receive off
interface ethernet1/1/2
 no shutdown
 switchport mode trunk
 switchport access vlan 1
 switchport trunk allowed vlan 101,201,301,401,501,601,901,1000-1001,3939
 mtu 9216
interface ethernet1/1/3
 no shutdown
 mtu 9216
interface ethernet1/1/4
 no shutdown
 mtu 9216
interface ethernet1/1/5
 no shutdown
 mtu 9216
interface ethernet1/1/6
 no shutdown
 mtu 9216
interface ethernet1/1/7
 no shutdown
interface ethernet1/1/8
 no shutdown
interface ethernet1/1/9
 no shutdown
interface ethernet1/1/10
 no shutdown
interface ethernet1/1/11
 no shutdown
interface ethernet1/1/12
 no shutdown
interface ethernet1/1/13
 no shutdown
interface ethernet1/1/14
 no shutdown
interface ethernet1/1/15
 no shutdown
interface ethernet1/1/16
 no shutdown
interface ethernet1/1/17
 no shutdown
 channel-group 17 mode active
 fec off
 no switchport
 mtu 9178
 negotiation off
 no lldp tlv-select basic-tlv management-address ipv4
 no lldp tlv-select basic-tlv management-address ipv6
interface ethernet1/1/18
 no shutdown
 channel-group 18 mode active
 fec off
 no switchport
 mtu 9178
 negotiation off
interface ethernet1/1/19
 no shutdown
 channel-group 19 mode active
 fec off
 no switchport
 mtu 9178
 negotiation off
interface ethernet1/1/20
 no shutdown
 channel-group 20 mode active
 fec off
 no switchport
 mtu 9178
 negotiation off
interface ethernet1/1/21
 no shutdown
interface ethernet1/1/22
 no shutdown
interface ethernet1/1/23
 description "VLTi link1"
 no shutdown
 no switchport
 mtu 9216
interface ethernet1/1/24
 no shutdown
 no switchport
 mtu 9216
interface ethernet1/1/25
 no shutdown
interface ethernet1/1/26
 no shutdown
interface ethernet1/1/27
 no shutdown
interface ethernet1/1/28
 no shutdown
interface ethernet1/1/29
 shutdown
interface ethernet1/1/30
 shutdown
interface ethernet1/1/31
 shutdown
interface ethernet1/1/32
 shutdown
interface ethernet1/1/33
 no shutdown
interface ethernet1/1/34
 no shutdown
interface ethernet1/1/35
 no shutdown
interface ethernet1/1/36
 no shutdown
interface ethernet1/1/37
 no shutdown
interface ethernet1/1/38
 no shutdown
interface ethernet1/1/39
 no shutdown
interface ethernet1/1/40
 no shutdown
interface ethernet1/1/41
 no shutdown
interface ethernet1/1/42
 no shutdown
interface ethernet1/1/43
 no shutdown
interface ethernet1/1/44
 no shutdown
interface ethernet1/1/45
 no shutdown
interface ethernet1/1/46
 no shutdown
interface ethernet1/1/47
 no shutdown
interface ethernet1/1/48
 no shutdown
interface ethernet1/1/49
 no shutdown
interface ethernet1/1/50
 no shutdown
interface ethernet1/1/51
 no shutdown
interface ethernet1/1/52
 no shutdown
interface ethernet1/1/53
 no shutdown
interface ethernet1/1/54
 no shutdown
interface ethernet1/1/55
 no shutdown
interface ethernet1/1/56
 no shutdown
interface virtual-network10101
 description Managment_VNI
 no shutdown
 mtu 9128
 ip address 10.60.97.2/24
 ip virtual-router address 10.60.97.1
 ipv6 address xxxx:xxx:xxxx:d0:a::2/80
 ipv6 virtual-router address xxxx:xxx:xxxx:d0:a::1
interface virtual-network10201
 description VSAN_VNI
 no shutdown
 mtu 9128
 ip address 10.60.100.34/27
 ip virtual-router address 10.60.100.33
interface virtual-network10301
 description vMotion_VNI
 no shutdown
 mtu 9128
 ip address 10.60.100.2/27
 ip virtual-router address 10.60.100.1
interface virtual-network10401
 description VTEP_VNI
 no shutdown
 mtu 9128
 ip address 10.60.98.2/26
 ip virtual-router address 10.60.98.1
interface virtual-network10501
 no shutdown
 mtu 9128
 ip address 10.60.98.66/26
 ip virtual-router address 10.60.98.65
interface virtual-network10601
 no shutdown
 mtu 9128
 ip address 10.60.103.66/26
 ip virtual-router address 10.60.103.65
interface virtual-network11000
 description "NSX-T Virtual Edge Peering VLAN 1000"
 no shutdown
 mtu 9128
 ip address 10.60.100.97/28
 ipv6 address xxxx:xxx:xxxx:d0:8::1/80
interface virtual-network11001
 description "NSX-T Virtual Edge Peering VLAN 1001"
 no shutdown
 mtu 9128
 ip address 10.60.100.113/28
 ipv6 address xxxx:xxx:xxxx:d0:9::1/80
logging source-interface mgmt1/1/1
management route 0.0.0.0/0 10.60.92.1
ip access-list XCLOUD-VTY-ACCESS
 seq 10 permit ip 10.54.35.208/32 any
 seq 20 permit ip 10.124.71.105/32 any
 seq 30 permit ip 68.87.23.34/32 any
 seq 40 permit ip 10.41.192.122/32 any
 seq 50 permit ip 165.137.122.210/32 any
 seq 60 permit ip 10.60.97.0/24 any
 seq 70 permit ip 10.60.98.0/26 any
 seq 80 permit ip 10.60.105.0/24 any
 seq 90 permit ip 10.60.106.0/26 any
 seq 100 permit ip 10.60.177.0/24 any
 seq 110 permit ip 10.60.178.0/26 any
 seq 120 permit ip 10.60.161.0/24 any
 seq 130 permit ip 10.60.162.0/26 any
 seq 140 permit ip 10.60.113.0/24 any
 seq 150 permit ip 10.60.114.0/26 any
 seq 160 permit ip 10.60.121.0/24 any
 seq 170 permit ip 10.60.122.0/26 any
 seq 200 permit ip 10.60.39.55/32 any
 seq 210 permit ip 10.30.0.0/16 any
 seq 220 permit ip 10.53.0.0/16 any
 seq 230 permit ip 10.166.0.0/16 any
 seq 240 permit ip 10.132.0.0/16 any
 seq 250 permit ip 10.6.28.0/22 any
 seq 260 permit ip 96.116.133.104/32 any
 seq 270 permit ip 96.118.251.70/32 any
 seq 280 permit ip 96.118.251.38/32 any
 seq 290 permit ip 96.116.134.8/32 any
 seq 1000 deny ip any any
ipv6 access-list V6-XCLOUD-VTY-ACCESS
 seq 10 permit ipv6 xxxx:xxx::/35 any
 seq 11 permit ipv6 xxxx:xxx:1031:13::a36:23d0/128 any
 seq 20 permit ipv6 xxxx:xxx:1436:4:10:124:71:105/128 any
 seq 30 permit ipv6 xxxx:xxx:fc0c:0:f816:3eff:fe2b:7e9f/128 any
 seq 40 permit ipv6 xxxx:xxx:fc0c:0:f816:3eff:fe2d:f8c0/128 any
 seq 50 permit ipv6 xxxx:xxx:fc18:2:f816:3eff:fea9:fec9/128 any
 seq 60 permit ipv6 xxxx:xxx:fc18:2:f816:3eff:fe86:aa73/128 any
 seq 1000 deny ipv6 any any
ip access-list XXXXXXX-ACCESS
 seq 10 permit ip 10.0.0.0/8 any
 seq 16 permit ip 100.88.0.0/13 any
 seq 20 permit ip 24.40.0.0/18 any
 seq 30 permit ip 24.40.64.0/20 any
 seq 35 permit ip 24.153.0.0/16 any
 seq 40 permit ip 68.85.0.0/16 any
 seq 50 permit ip 68.86.0.0/15 any
 seq 60 permit ip 69.139.128.0/17 any
 seq 65 permit ip 69.252.80.0/23 any
 seq 70 permit ip 69.252.194.14/32 any
 seq 80 permit ip 76.96.0.0/17 any
 seq 90 permit ip 96.108.0.0/14 any
 seq 100 permit ip 96.112.8.20/32 any
 seq 105 permit ip 96.112.192.26/32 any
 seq 110 permit ip 96.112.246.0/23 any
 seq 120 permit ip 96.114.8.133/32 any
 seq 125 permit ip 96.114.67.22/32 any
 seq 130 permit ip 96.114.153.101/32 any
 seq 140 permit ip 96.115.208.0/23 any
 seq 150 permit ip 147.191.0.0/16 any
 seq 160 permit ip 162.151.0.0/16 any
 seq 170 permit ip 165.137.0.0/16 any
 seq 180 permit ip 169.152.0.0/16 any
 seq 190 permit ip 172.16.0.0/12 any
 seq 210 permit udp any any eq 67
 seq 220 permit udp any any eq 68
 seq 230 permit udp any any eq 123
ipv6 access-list V6-XXXXXXX-ACCESS
 seq 5 permit ipv6 fe80::/10 any
 seq 20 permit ipv6 xxxx:xxx:fe16:103:69:252:194:14/128 any
 seq 30 permit ipv6 xxxx:xxx:fe16:10c:96:114:8:133/128 any
 seq 40 permit ipv6 xxxx:xxx:fe33:1001:f816:3eff:fed3:5d7a/128 any
 seq 50 permit ipv6 2600:1f14:e0f:af00::/64 any
 seq 60 permit ipv6 2600:1f18:6de:e800::/64 any
 seq 70 deny ipv6 any any
route-map local_origin_only permit 10
 match as-path local_origin
route-map V4_CORE_OUT permit 10
 match ip address prefix-list V4-CONNECTED-PFX
route-map V6_CORE_OUT permit 10
 match ipv6 address prefix-list V6-CONNECTED-PFX
router bgp xxxxxx6692
 router-id x.x.x.x
 address-family ipv4 unicast
  aggregate-address 10.60.96.0/21
  redistribute connected route-map V4_CORE_OUT
 address-family ipv6 unicast
  aggregate-address xxxx:xxx:xxxx:d0::/64
  redistribute connected route-map V6_CORE_OUT
 neighbor 10.210.10.96
  description Connected_To_Spine_s5g1
  remote-as xxxxxx6528
  timers 3 10
  no shutdown
   route-map local_origin_only out
 neighbor 10.210.14.96
  description Connected_To_Spine_s13g1
  timers 3 10
  no shutdown
 neighbor 10.210.18.96
  description Connected_To_Spine_s5g2
  timers 3 10
  no shutdown
 neighbor 10.210.22.96
  description Connected_To_Spine_s13g2
  timers 3 10
  no shutdown
 neighbor xxxx:xxx:xxx:b46::a60
  timers 3 10
  no shutdown
   no activate
   activate
 neighbor xxxx:xxx:xxx:b46::e60
  timers 3 10
  no shutdown
   no activate
   activate
 neighbor xxxx:xxx:xxx:b46::1260
  timers 3 10
  no shutdown
   no activate
   activate
 neighbor xxxx:xxx:xxx:b46::1660
  timers 3 10
  no shutdown
   no activate
   activate
 neighbor 10.60.96.129
  description Connected_To_Mgmt_Rack1_Leaf2
  bfd
  remote-as xxxxxx6692
  no shutdown
 neighbor xxxx:xxx:xxxx:d0:1::129
  bfd
  no shutdown
   no activate
   activate
 neighbor 10.60.100.130
  description Connected_To_ESG1_Uplink1
  bfd
  remote-as xxxxxx5108
  timers 4 12
  no shutdown
 neighbor xxxx:xxx:xxxx:d0:2::2
  bfd
  timers 4 12
  no shutdown
   no activate
   activate
 neighbor 10.60.100.131
  description Connected_To_ESG2_Uplink1
  bfd
  timers 4 12
  no shutdown
 neighbor xxxx:xxx:xxxx:d0:2::3
  bfd
  timers 4 12
  no shutdown
   no activate
   activate
 neighbor 10.60.100.132
  description Connected_To_ESG3_Uplink1
  bfd
  timers 4 12
  no shutdown
 neighbor xxxx:xxx:xxxx:d0:2::4
  bfd
  timers 4 12
  no shutdown
   no activate
   activate
 neighbor 10.60.100.133
  description Connected_To_ESG4_Uplink1
  bfd
  timers 4 12
  no shutdown
 neighbor xxxx:xxx:xxxx:d0:2::5
  bfd
  timers 4 12
  no shutdown
   no activate
   activate
 neighbor 10.60.100.110
  description Connected_To_VirtualEdge1_Uplink1
  bfd
  remote-as xxxxxx5107
  timers 4 12
  no shutdown
 neighbor xxxx:xxx:xxxx:d0:8::7
  bfd
  timers 4 12
  no shutdown
   no activate
vlt-domain 1
 backup destination 10.60.92.5
 discovery-interface ethernet1/1/23-1/1/24
 peer-routing
 primary-priority 1
 vlt-mac 00:00:00:11:11:11
line vty
 ip access-class XCLOUD-VTY-ACCESS
 ipv6 access-class V6-XCLOUD-VTY-ACCESS
 description Management_VNI_10101
 vxlan-vni 10101
  remote-vtep 10.60.96.2
  remote-vtep 10.60.96.3
 description VSAN_VNI_10201
 vxlan-vni 10201
 description vMotion_VNI_10301
 vxlan-vni 10301
 description NSX_VTEP_VNI_10401
 vxlan-vni 10401
 description Host_TEP_VNI_10501
 vxlan-vni 10501
 description Edge_TEP_VNI_10601
 vxlan-vni 10601
 description NSX_T_Virtual_Edge_VNI
 vxlan-vni 11000
 vxlan-vni 11001
 description VxRail_Discovery_VNI_13939
 vxlan-vni 13939
snmp-server contact "Contact Support"
telemetry
sw1001b
sw1001b# show running-configuration
! Version 10.5.2.3
! Last configuration change at Feb  04 00:23:27 2022
ip vrf default
hostname sw1001b
port-group 1/1/1
 mode Eth 25g-4x
port-group 1/1/2
 mode Eth 25g-4x
port-group 1/1/3
 mode Eth 25g-4x
port-group 1/1/4
 mode Eth 25g-4x
port-group 1/1/5
 mode Eth 25g-4x
port-group 1/1/6
 mode Eth 25g-4x
port-group 1/1/7
 mode Eth 25g-4x
port-group 1/1/8
 mode Eth 25g-4x
port-group 1/1/9
 mode Eth 25g-4x
port-group 1/1/10
 mode Eth 25g-4x
port-group 1/1/11
 mode Eth 25g-4x
port-group 1/1/12
 mode Eth 25g-4x
port-group 1/1/13
 mode Eth 100g-2x
port-group 1/1/14
 mode Eth 100g-2x
port-group 1/1/15
 mode Eth 100g-1x
port-group 1/1/16
 mode Eth 100g-1x
port-group 1/1/17
 mode Eth 100g-1x
port-group 1/1/18
 mode Eth 100g-1x
interface vlan1
 shutdown
interface vlan101
 no shutdown
 mtu 9128
interface vlan201
 no shutdown
 mtu 9128
interface vlan301
 no shutdown
 mtu 9128
interface vlan401
 no shutdown
 mtu 9128
interface vlan501
 no shutdown
 mtu 9128
interface vlan601
 no shutdown
 mtu 9128
interface vlan901
 no shutdown
 mtu 9216
 ip address 10.60.100.161/27
 ipv6 address xxxx:xxx:xxxx:d0:3::1/80
interface vlan1000
 no shutdown
 mtu 9216
interface vlan1001
 no shutdown
 mtu 9128
interface vlan3939
 no shutdown
interface vlan4000
 no shutdown
 mtu 9128
 ip address 10.60.96.129/31
 ipv6 address xxxx:xxx:xxxx:d0:1::129/127
 no shutdown
 no switchport
 mtu 9178
 ip address 10.210.10.99/31
 ipv6 address xxxx:xxx:280:b46::a63/127
 no shutdown
 no switchport
 mtu 9178
 ip address 10.210.14.99/31
 ipv6 address xxxx:xxx:280:b46::e63/127
 no shutdown
 no switchport
 mtu 9178
 ip address 10.210.18.99/31
 ipv6 address xxxx:xxx:280:b46::1263/127
 description Connected_to_Spine_s13g2_14.1
 no shutdown
 no switchport
 mtu 9178
 ip address 10.210.22.99/31
 ipv6 address xxxx:xxx:280:b46::1663/127
interface loopback0
 no shutdown
 mtu 9178
 ip address 96.109.93.152/31
interface loopback1
 no shutdown
nve
interface mgmt1/1/1
 no shutdown
 no shutdown
 no switchport
 mtu 9216
 no shutdown
 mtu 9216
 no shutdown
 mtu 9216
 no shutdown
 mtu 9216
 no shutdown
 mtu 9216
 no shutdown
 mtu 9216
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 fec off
 no switchport
 mtu 9178
 negotiation off
 no shutdown
 fec off
 no switchport
 mtu 9178
 negotiation off
 no shutdown
 fec off
 no switchport
 mtu 9178
 negotiation off
 no shutdown
 fec off
 no switchport
 mtu 9178
 negotiation off
 no shutdown
 no shutdown
 no shutdown
 no switchport
 mtu 9216
 no shutdown
 no switchport
 mtu 9216
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 mtu 9128
 ip address 10.60.97.3/24
 ipv6 address xxxx:xxx:xxxx:d0:a::3/80
 no shutdown
 mtu 9128
 ip address 10.60.100.35/27
 no shutdown
 mtu 9128
 ip address 10.60.100.3/27
 no shutdown
 mtu 9128
 ip address 10.60.98.3/26
 no shutdown
 mtu 9128
 ip address 10.60.98.67/26
 no shutdown
 mtu 9128
 ip address 10.60.103.67/26
 no shutdown
 mtu 9128
 ip address 10.60.100.98/28
 ipv6 address xxxx:xxx:xxxx:d0:8::2/80
 no shutdown
 mtu 9128
 ip address 10.60.100.114/28
 ipv6 address xxxx:xxx:xxxx:d0:9::2/80
ip access-list XXXXXX-ACCESS
ipv6 access-list V6-XXXXXX-ACCESS
 router-id 96.109.93.152
  timers 3 10
  no shutdown
  timers 3 10
  no shutdown
 neighbor xxxx:xxx:280:b46::a60
  timers 3 10
  no shutdown
   no activate
   activate
 neighbor xxxx:xxx:280:b46::e60
  timers 3 10
  no shutdown
   no activate
   activate
 neighbor xxxx:xxx:280:b46::1260
  timers 3 10
  no shutdown
   no activate
   activate
 neighbor xxxx:xxx:280:b46::1660
  timers 3 10
  no shutdown
   no activate
   activate
  bfd
  timers 4 12
  no shutdown
  bfd
  timers 4 12
  no shutdown
   no activate
   activate
  bfd
  timers 4 12
  no shutdown
  bfd
  timers 4 12
  no shutdown
   no activate
   activate
  bfd
  timers 4 12
  no shutdown
  bfd
  timers 4 12
  no shutdown
   no activate
   activate
  bfd
  timers 4 12
  no shutdown
  bfd
  timers 4 12
  no shutdown
   no activate
   activate
  bfd
  timers 4 12
  no shutdown
  bfd
  timers 4 12
  no shutdown
   no activate
 neighbor 10.60.96.128
  description Connected_To_Mgmt_Rack1_Leaf1
  bfd
  no shutdown
 neighbor xxxx:xxx:xxxx:d0:1::128
  bfd
  no shutdown
   no activate
   activate
 neighbor 10.210.10.98
  timers 3 10
  no shutdown
 neighbor 10.210.18.98
  timers 3 10
  no shutdown
vlt-domain 1
 backup destination 10.60.92.4
 peer-routing
 primary-priority 1
line vty
 vxlan-vni 10101
 vxlan-vni 10201
 vxlan-vni 10301
 vxlan-vni 10401
 vxlan-vni 10501
 vxlan-vni 10601
 vxlan-vni 11000
 vxlan-vni 11001
 vxlan-vni 13939
telemetry
sw1001b#
Spine1_G1
s5g1# show running-configuration
! Version 10.5.2.3
! Last configuration change at Feb  03 23:38:11 2022
ip vrf default
system-user linux++++admin password ****
hostname s5g1
port-group 1/1/1
 mode Eth 25g-4x
port-group 1/1/2
 mode Eth 25g-4x
port-group 1/1/3
 mode Eth 25g-4x
port-group 1/1/4
 mode Eth 25g-4x
port-group 1/1/5
 mode Eth 25g-4x
port-group 1/1/6
 mode Eth 25g-4x
port-group 1/1/7
 mode Eth 25g-4x
port-group 1/1/8
 mode Eth 25g-4x
port-group 1/1/9
 mode Eth 25g-4x
port-group 1/1/10
 mode Eth 25g-4x
port-group 1/1/11
 mode Eth 25g-4x
port-group 1/1/12
 mode Eth 25g-4x
port-group 1/1/13
 mode Eth 100g-2x
port-group 1/1/14
 mode Eth 100g-2x
port-group 1/1/15
 mode Eth 100g-1x
port-group 1/1/16
 mode Eth 100g-1x
port-group 1/1/17
 mode Eth 100g-1x
port-group 1/1/18
 mode Eth 100g-1x
interface vlan1
 no shutdown
interface port-channel13
 description Connected_to_Leaf_sw1001a_17.1
 no shutdown
 no switchport
 mtu 9178
 ip address 10.210.10.96/31
 ipv6 address xxxx:xxx:xxx:b46::a60/127
interface port-channel14
 description Connected_to_Leaf_sw1001b_17.1
 no shutdown
 no switchport
 mtu 9178
 ip address 10.210.10.98/31
 ipv6 address xxxx:xxx:xxx:b46::a62/127
interface mgmt1/1/1
 no shutdown
 ip address dhcp
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 channel-group 13 mode active
 fec off
 no switchport
 mtu 9178
 negotiation off
 no shutdown
 channel-group 14 mode active
 fec off
 no switchport
 mtu 9178
 negotiation off
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no switchport
 ip address dhcp
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
ip route 0.0.0.0/0 192.168.0.1
router bgp xxxxxx6528
  network 192.168.0.0/24
 neighbor 10.210.10.97
  description Connected_To_Leaf_sw1001a
  timers 3 10
  no shutdown
   default-originate
 neighbor 10.210.10.99
  description Connected_To_Leaf_sw1001b
  timers 3 10
  no shutdown
   default-originate
telemetry
Spine2_G1
s5g2# show running-configuration
! Version 10.5.2.3
! Last configuration change at Feb  04 00:45:09 2022
ip vrf default
hostname s5g2
port-group 1/1/1
 mode Eth 25g-4x
port-group 1/1/2
 mode Eth 25g-4x
port-group 1/1/3
 mode Eth 25g-4x
port-group 1/1/4
 mode Eth 25g-4x
port-group 1/1/5
 mode Eth 25g-4x
port-group 1/1/6
 mode Eth 25g-4x
port-group 1/1/7
 mode Eth 25g-4x
port-group 1/1/8
 mode Eth 25g-4x
port-group 1/1/9
 mode Eth 25g-4x
port-group 1/1/10
 mode Eth 25g-4x
port-group 1/1/11
 mode Eth 25g-4x
port-group 1/1/12
 mode Eth 25g-4x
port-group 1/1/13
 mode Eth 100g-2x
port-group 1/1/14
 mode Eth 100g-2x
port-group 1/1/15
 mode Eth 100g-1x
port-group 1/1/16
 mode Eth 100g-1x
port-group 1/1/17
 mode Eth 100g-1x
port-group 1/1/18
 mode Eth 100g-1x
interface vlan1
 no shutdown
 description Connected-to-Leaf-sw1001a-19.1
 no shutdown
 no switchport
 mtu 9178
 ip address 10.210.18.96/31
 ipv6 address xxxx:xxx:xxx:b46::1660/127
 description Connected-to-Leaf-sw1001b-19.1
 no shutdown
 no switchport
 mtu 9178
 ip address 10.210.18.98/31
 ipv6 address xxxx:xxx:xxx:b46::1262/127
interface mgmt1/1/1
 no shutdown
 ip address dhcp
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 fec off
 no switchport
 mtu 9178
 negotiation off
 no shutdown
 fec off
 no switchport
 mtu 9178
 negotiation off
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no switchport
 ip address dhcp
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
 no shutdown
  network 10.60.0.0/16
 neighbor 10.210.18.97
  timers 3 10
  no shutdown
   default-originate
 neighbor xxxx:xxx:xxx:b46::a61
  timers 3 10
  no shutdown
   no activate
   activate
 neighbor 10.210.18.99
  description Connected_To_Leaf_sw1001b_19.1
  timers 3 10
  no shutdown
   default-originate
Too a big post to read, in short, since switches got IP addresses from your broadband router, it works. rest of the network it will not, that is the reason suggested IOL router can do NAT for all devices. (make sense ?)
BB
Yes. Do I need to put a public subnet between the IOL and the Spine's ?
Hello
How can this be?  All devices point via "NET"  so what is spine1/2 being natted by , use whatever device that is to perform network translation for spine1_G1, Spine2_G1
Kind Regards
Paul
IOL router does the router outside interface (which get IP address from your DSL router) , internally you can use any RFC 1918 address space - in short?
is that works /
BB
As Paul has said and I have already mentioned if the spines can ping the WAN then something must be doing the NAT for the 10.x.x.x IPs which I suspect is your home router so just use that device to NAT the leaf switches.
If you can't use the home router, perhaps because it only does NAT for directly connected subnets, then use an IOL router and no you don't need a public subnet, just make sure the WAN side of the IOL router is in the same subnet as the LAN side of your home router and NAT all devices to the WAN IP of your IOL device.
That should work but still not clear what is actually doing what in your lab.
Jon
