How to postpone DNS lookup until after ISP DHCP lease
bcerny
A branch office router is configured to connect to the HQ VPN hub router. The tunnel destination is 'dynamic' and there is an IKEv2 client configuration stanza to help with this. Here's a chunk of the startup config:
ip domain lookup
ip name-server 2001:4860:4860::8888
crypto ikev2 client flexvpn default
client connect Tunnel1
peer 1 fqdn hub1.example.com ipv6
peer 2 fqdn hub2.example.com ipv6
peer reactivate
interface Tunnel1
description --> HQ VPN Hub
no ip address
ipv6 unnumbered Loopback6
ipv6 enable
--- lines omitted ---
tunnel source GigabitEthernet1
tunnel destination dynamic
tunnel protection ipsec profile FLEX
interface GigabitEthernet1
description --> ISP
no ip address
ipv6 address autoconfig default
ipv6 enable
However, the DNS server is not reachable during boot -- the WAN interface (Gig1) grabs an ISP DHCP lease. As a result, the router cannot resolve the host names and I end up with this:
peer reactivate
Is there a way to postpone DNS lookups until after getting a DHCP lease?
Or do I need to craft an EEM script to configure the "crypto ikev2 client" stanza after the WAN interface comes up and the DNS server is reachable?
From hack to utter kludge: had to work-around IOS-XE bug by changing the IP SLA ping target from an IPv6 address to an IPv4 address:
ip sla 6
 icmp-echo 9.9.9.9
frequency 15
ip sla schedule 6 life 600 start-time now
track 6 ip sla 6 reachability
EEM script triggered by tracking object 6:
event manager applet IKEv2_CLIENT_CONFIG authorization bypass
event track 6 state up
action 110 cli command enable
action 120 cli command "conf term"
action 130 cli command "crypto ikev2 client flexvpn default"
action 140 cli command "peer 1 fqdn hub1.example.com ipv6"
action 150 cli command "peer 2 fqdn hub2.example.com ipv6"
action 160 cli command "end"
Et voilà - as soon as DNS is reachable...
%TRACK-6-STATE: 6 ip sla 6 reachability Down -> Up
%SYS-5-CONFIG_I: Configured from console by on vty0 (EEM:IKEv2_CLIENT_CONFIG)
%CRYPTO-5-IKEV2_SESSION_STATUS: Crypto tunnel v2 is UP.
...the IKEv2 client configuration falls into place, and the IPv6 tunnel connects right away.
5 Replies 5
balaji.bandi
for this i suggest using EEM is best option here to delay the process - until properly got DNS resolution and the re-initiate the connection.
BB
Hello Balaji,
Yes, I thought an EEM would do the trick. Doesn't IP SLA support IPv6?  I tried:
ip sla 6
 icmp-echo 2001:4860:4860::8888
frequency 15
 But then at boot time I see this on the console:
% Invalid input detected at '^' marker.
Note: If I paste the SLA configuration into config mode after the router has booted, then IOS-XE accepts the "icmp-echo 2001:4860:4860::8888" without complaint (!?!)   I'm running this:
Cisco Catalyst 8000V Edge (virtual router)
Cisco IOS Software [Bengaluru], Virtual XE Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 17.6.3a
ip sla 6
 icmp-echo 9.9.9.9
frequency 15
Glad all good now, thank you sharing the solution to community appriciated.
BB
You have dual Hubs and use client profile to force spoke to use one of hub'
Until now it OK'
The Fqdn of hub is resovle by DNS reach via tunnel?
The fqdn of hub need to resolve by ISP DNS not by Hub internal DNS.
I think you need to use domain-list in such that the spoke use ISP dns to resolve hub IP and use internal DNS for other requests.
MHM
