How to reduce or eliminate output queue drop?
Santosh Shetty
Getting outpug queue drop on router
 Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 38827
  Queueing strategy: Class-based queueing
  Output queue: 0/40 (size/max)
  1 minute input rate 11256000 bits/sec, 3444 packets/sec
  1 minute output rate 19425000 bits/sec, 3882 packets/sec
We get queue drop even when link utlization is low. RX, TX 10%.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
If cause of your drops are because of transient bursts, increasing egress queue limit might mitigate.
PS:
BTW, "low" link utilization doesn't preclude having queue drops.  Conversely you can have 100% utilization with no drops and no egress queue.
Carlos de Armas
Check the output queue size and if you have any QoS that could be the cause.
Also you might want to take a look to this doc:
http://www.cisco.com/c/en/us/support/docs/routers/10000-series-routers/6343-queue-drops.html
