ACL for BGP
gongya001
On R1
access-list 10 permit 7.7.7.7 log
route-map set-LP-300 permit 10
 match ip address 10
 set local-preference 300
route-map set-IP-300 permit 20
router bgp 65001
 address-family ipv4
  network 1.1.1.1 mask 255.255.255.255
  neighbor 2.2.2.2 activate
  neighbor 3.3.3.3 activate
  neighbor 3.3.3.3 soft-reconfiguration inbound
  neighbor 3.3.3.3 route-map set-LP-300 in
 exit-address-family
R1(config)#do show access-lists
Standard IP access list 10
    10 permit 7.7.7.7 log (1 match)
On R4
 match ip address 10
router bgp 100
 bgp log-neighbor-changes
 neighbor 20.10.1.2 remote-as 65001
 neighbor 20.10.2.3 remote-as 65001
 neighbor 30.10.1.5 remote-as 200
 neighbor 30.10.2.6 remote-as 300
 neighbor 30.10.2.6 route-map set-IP-300 in
R4#show access-lists
Why no match on R4 ?
thanks !!
4 Accepted Solutions
Richard Burts
Is it possible that R4 had already learned the route before you configured the ACL and the route map? What happens if you stop and restart the neighbor relationship on R4?
Rick
Rick
Francesco Molino
On R4, you’re using set-IP-300 as route-map instead of set-LP-300.
Also I highly believe you’ve done a spelling issue because set-LP-300 set local-pref for 7.7.7.7 and I guest the set-IP-300 permit 20 to take all others as default should have been set-LP-300 permit 20.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco
You read more carefully than I did. Congratulations. So often the solution to a problem is in a simple detail that we have overlooked.
Rick
Rick
You're welcome.
No problem we're here to help.
Sometimes the issue is right in front of us but to concentrate to see it.
Francesco
6 Replies 6
Richard Burts
Rick
Rick
Francesco Molino
Francesco
Francesco
Rick
Rick
thanks so much.  Sorry for my carelessness.
You're welcome.
Francesco
thanks so much.
sorry for my carelessness.
