How to reset all switch interface statistics
blue4cisco
I want to reset all switch's interfaces counter( statistics) showing as input, output & error etc information.
sourabhagarwal
Level 4
Level 4
"clear counters" command will reset counters on all interfaces. if you are looking to reset counters on a apecific interface you can enter "clear counters " command.
HTH, rate if it does ...
