How to see and set transmit interval (Tc) in QoS
prima.ramadhan
Anybody knows how to see the transmit interval (Tc)? I tried the command "show traffic-shape", but looks like that command only works for frame relay traffic shaping. I configured "police" in ethernet interface, with bandwidth of 320000 bps without specifying the Bc. The router then automatically set the Bc to 1/32 of the CIR, which is 10000 byte. If we follows the CIR=Bc/Tc, then Tc=Bc/CIR, then we got the Tc = 0.25 s. The problem is, from what I've read from cisco documentation, Tc is between 10 ms - 125 ms. This means that the value from the router doesn't conform with the document. How could this happen? I tried this using cisco 7200 series.
Gregory Camp
Prima,
I think you are confusing traffic shaping with policing. The policer adds more tokens to the bucket based on the formula below. Tc has no meaning in policing.
[(Current_arrival_time - previous_arrival_time) * CIR]/8
If you want to configure shaping, use the "shape average" command. Once you configure this you can run "show policy-map interface" and see the Bc value. From this you can calculate Tc.
On the ISR platform you can pretty much set the Tc to whatever you want. I personally would leave it at the default value for Tc = 4ms in 12.4 code.
Hmm.. okay. Anyway, how to set the Tc in ISR platform? I haven't found the way yet.
There is no way to directly set the Tc. You need to configure Bc and the CIR to make the Tc you want using the formula below.
Tc = CIR/Bc
policy-map shape-out
class class-default
shape average 320000 Bc_VALUE
Joseph W. Doherty
If you're using the traffic-shape command, the 2nd and 3rd parameters configure Bc and Be, which will adjust Tc.
